Do you have to run a cast iron fork with the Posi-Lok?? - JeepForum.com
post #1 of 4 Old 04-20-2005, 12:28 PM Thread Starter
condoor
I am running a posi-lok on an axle that I just put under my jeep and it looks like I need to replace the shift fork (lots of slop), and was wondering if I really should spring for the cast iron fork or if people are running their aluminum forks without prob.
thx
condoor is offline
post #2 of 4 Old 04-20-2005, 07:56 PM
socko
socko's Avatar
When I installed a Posi-lok I went ahead and switched over to the iron fork because I never had much luck with that aluminum fork. It was always bending and cracking. And this cast iron fork seems MUCH stronger, I dont think I could break it if I tried. But I am not sure if it requires a change, I just dont trust the aluminum.
socko is offline
post #3 of 4 Old 04-20-2005, 09:01 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
been running my alum replacement for about 5 months now. no problems. the original lasted 200K+ miles. the posi isn't going make it wear any faster. definitely replace it with something though either way. i didn't when i should have and ended up having to do it in the winter when i needed 4wd
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #4 of 4 Old 04-20-2005, 11:37 PM
socko
socko's Avatar
I guess maybe I was just having bad luck
oh well, everything is going fine now.
socko is offline
Should I paint my cast iron wheel cylinders TheDragonfly TJ Wrangler Technical Forum 8 02-19-2010 04:10 PM
broken shift fork with posi-lock type setup? dave_dj1 YJ Wrangler Technical Forum 6 04-26-2009 08:48 PM
where can i find cast shift fork giggityjeeper YJ Wrangler Technical Forum 6 08-17-2007 01:33 PM
Factory Cast Iron or Pacesetter muddyforeman TJ Wrangler Technical Forum 5 07-10-2005 04:20 PM
My posi-lock isn't so 'posi' - help! condoor YJ Wrangler Technical Forum 4 04-04-2005 07:00 PM
