Do these cross hatches look good? - JeepForum.com
post #1 of 14 Old 11-08-2013, 03:52 PM Thread Starter
Rino1425
Need to make sure these look good before I drop the pistons in
Rino1425 is offline
post #2 of 14 Old 11-08-2013, 04:13 PM
napaguy
Im not an engine builder but they look deep? Might be just the flash making it look that way. The engines I have seen usually require a closer look to see the cross hatching. Just my .02
napaguy is offline
post #3 of 14 Old 11-08-2013, 04:29 PM
bpounds
bpounds's Avatar
Hard to tell from a picture. But they look deep to me too, and too close to radial around the bore. Like you needed to move the hone faster up and down relative to the RPM.
I'm judging depth by comparison to the top of the deck. The bores should look pretty close to that.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #4 of 14 Old 11-08-2013, 04:40 PM Thread Starter
Rino1425
You can feel them, but not by much. I used a rental kit from the auto parts store that attaches to a drill
Rino1425 is offline
post #5 of 14 Old 11-08-2013, 04:40 PM
Mark05059
Looks like your hone is too coarse... and your not moving it up and down fast enough... that and put LOTS of hone oil to it
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 14 Old 11-08-2013, 04:57 PM Thread Starter
Rino1425
Re did them again. This time took some of the tension off of the hone so it would be lighter and used more ATF
Rino1425 is offline
post #7 of 14 Old 11-08-2013, 05:00 PM
Peety
They look a little too deep and too closely spaced. I would suggest a Ball Hone in a variable speed drill. I always used Brake Kleen as a lubricating medium. Top of bore to bottom cycle every 2-3 seconds
http://www.popularhotrodding.com/eng.../photo_06.html
Check this link out, damn impressive, lol
Peety is offline
post #8 of 14 Old 11-08-2013, 05:01 PM Thread Starter
Rino1425
Here's a new pic
Rino1425 is offline
post #9 of 14 Old 11-08-2013, 05:04 PM
Mark05059
looks like your using a straight hone? Try a fine grit ball hone instead... that and flood the heck out of the cyl with lubricant... what your using is too coarse and isn't getting you the finish that your looking for...
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #10 of 14 Old 11-08-2013, 05:12 PM
ninjakid
1987 YJ Wrangler
If you are just trying to put a cross hatch in it you should try to get or rent a ball hone.
Those look too deep imo.
This is what a cross hatch from a ball hone looks like
Did the hone you rent look like this?
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #11 of 14 Old 11-08-2013, 05:29 PM Thread Starter
Rino1425
Yes it did look just like that one. So I need a ball hone?
Rino1425 is offline
post #12 of 14 Old 11-08-2013, 07:49 PM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
Did you check the bore tolerances? Hard to tell from pics alone, but the cylinders look like they might have some issues.
I hate computer updates
Chrisnvegas is offline
post #13 of 14 Old 11-08-2013, 07:59 PM Thread Starter
Rino1425
Yes, they were good. I really didn't even have rings at the ridges
Rino1425 is offline
post #14 of 14 Old 11-09-2013, 01:14 PM
jsawduste
2006 YJ Wrangler
If they didn't they do now.
Visual doesn't matter. Did you measure them ? And then measure them again after they have been honed to death ?
jsawduste is offline
