-   -   Do these cross hatches look good? (http://www.jeepforum.com/forum/f12/do-these-cross-hatches-look-good-1771793/)
Rino1425 11-08-2013 02:52 PM
1 Attachment(s)
Need to make sure these look good before I drop the pistons in
napaguy 11-08-2013 03:13 PM
Im not an engine builder but they look deep? Might be just the flash making it look that way. The engines I have seen usually require a closer look to see the cross hatching. Just my .02
bpounds 11-08-2013 03:29 PM
Hard to tell from a picture. But they look deep to me too, and too close to radial around the bore. Like you needed to move the hone faster up and down relative to the RPM.
I'm judging depth by comparison to the top of the deck. The bores should look pretty close to that.
Rino1425 11-08-2013 03:40 PM
You can feel them, but not by much. I used a rental kit from the auto parts store that attaches to a drill
Mark05059 11-08-2013 03:40 PM
Looks like your hone is too coarse... and your not moving it up and down fast enough... that and put LOTS of hone oil to it :)
Rino1425 11-08-2013 03:57 PM
Re did them again. This time took some of the tension off of the hone so it would be lighter and used more ATF
Peety 11-08-2013 04:00 PM
They look a little too deep and too closely spaced. I would suggest a Ball Hone in a variable speed drill. I always used Brake Kleen as a lubricating medium. Top of bore to bottom cycle every 2-3 seconds
http://www.popularhotrodding.com/eng.../photo_06.html
Check this link out, damn impressive, lol:wave:
Rino1425 11-08-2013 04:01 PM
1 Attachment(s)
Here's a new pic
Mark05059 11-08-2013 04:04 PM
looks like your using a straight hone? Try a fine grit ball hone instead... that and flood the heck out of the cyl with lubricant... what your using is too coarse and isn't getting you the finish that your looking for...
ninjakid 11-08-2013 04:12 PM
2 Attachment(s)
If you are just trying to put a cross hatch in it you should try to get or rent a ball hone.
Those look too deep imo.
This is what a cross hatch from a ball hone looks like
Attachment 826833
Did the hone you rent look like this?
Attachment 826849
Rino1425 11-08-2013 04:29 PM
Yes it did look just like that one. So I need a ball hone?
Chrisnvegas 11-08-2013 06:49 PM
Did you check the bore tolerances? Hard to tell from pics alone, but the cylinders look like they might have some issues.
Rino1425 11-08-2013 06:59 PM
Yes, they were good. I really didn't even have rings at the ridges
jsawduste 11-09-2013 12:14 PM
If they didn't they do now.
Visual doesn't matter. Did you measure them ? And then measure them again after they have been honed to death ?
The time now is 05:29 PM.
