Do I really need this.... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Do I really need this....
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 08-22-2008, 12:07 AM   #1
zekthecat
I have an 88 YJ 4.2 nuttered weber carb. The question that I have is: Is the L shaped tube that goes from the intake to exhuast manifold needed. I have no clue on what it is there for and didn't know if it is needed. Thanks to everyone with helping me in my NOOBIE questions that I have asked. Still just getting into the whole Jeep thing.
zekthecat is offline   Reply With Quote
Unread 08-22-2008, 04:06 AM   #2
timatoe
I can't place the part off the top of my head, but if it's emissions related, then you don't need it due to the Nutter Bypass, it won't be working anyhow.
As for some other questions that are bound to arise, read through this site http://home.sprynet.com/~dale02/ there's tons of good info in there on the 4.2.
timatoe is offline   Reply With Quote
Unread 08-22-2008, 04:29 AM   #3
Brandon_YJ
1987 YJ Wrangler
sounds like the EGR tube
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using Elinks in a (text only) terminal. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused click here to see how I view the forum.
Brandon_YJ is offline   Reply With Quote
Unread 08-22-2008, 09:40 AM   #4
zekthecat
Thats sounds like it. do I really need the EGR tube?
Unread 08-22-2008, 10:01 AM   #5
Delta347
T-Rex Bait
Delta347's Avatar
Well what the EGR does is recirculates exhaust gases into the combustion chamber (or intake first). What this does is pass already combusted materials back into the combustion chamber resulting in fewer materials to be well combusted.
Basically if there is less to break down then there is less energy being liberated. Less liberation = Less Heat.
This causes you to get LESS Power out of each cycle of the engine BUT it grants Better fuel economy by lowering the combustion temperature and the amount of NOx gas being released (which can help on smog).
If you take out the EGR you will get:
1. A gain in Power
2. A higher operating temperature
3. Lowered Fuel Economy (lower MPG)
Leave it in, and its the opposite of that.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline   Reply With Quote
Unread 08-22-2008, 12:03 PM   #6
zekthecat
Delta, Thanks for that. The EGR vavle is not hooked up so the tube on the bottom of the intake going into the side of the exhust manifold is not needed and I can cap the holes. Right
