Do i have to pull the push rods for head gasket. - JeepForum.com
post #1 of 12 Old 04-30-2013, 06:42 AM Thread Starter
mtidwell
Hey guys i have a question.
I am doing a head gasket.
A buddy says with the 2 of us doing it we can pull the head without removing the manifolds. I agree,,, he saus to leave rocker arms and push rods in place too?
What do yall think?
The Fireman
mtidwell is offline
post #2 of 12 Old 04-30-2013, 06:54 AM
roadyrob
1987 YJ Wrangler
I think your buddy is no mechanic. don't take shortcuts, do the job right or you will probably be doing it twice.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 12 Old 04-30-2013, 07:20 AM
88RedWrangler
X2 if you don't pull them and you damage them, you'll be worse off than you are now. Get yourself some large ziplock bags and place the rods in and label them. Put em back where they came from. I prefer bags to boxes because you don't get the little cardboard pieces on them. Good luck and take your time.
88RedWrangler is offline
post #4 of 12 Old 04-30-2013, 08:56 AM
hdfxrs91
1987 YJ Wrangler
That would be a neat trick if you can make all the pushrods stand straight up as you're putting the head back on.
hdfxrs91 is offline
post #5 of 12 Old 04-30-2013, 11:45 AM
50rck
Did I read that right, "Pull the head without removing the manifolds?" The manifolds are attached to the head, so please explain this. Never mind, take it to a different friend or a good mechanic. And yes, you need to remove the push rods. Why is that such a big deal?
1991 YJ, rebuilt 4.0L in spring 2009 at 234,000 miles, no lift yet, slightly offset wheels, 235/75/15 tires for now, rag top, sold the hard top. Over 35,000 miles on the rebuild and counting.
2006 Jeep Liberty. Nothing special, all stock.
50rck is offline
post #6 of 12 Old 04-30-2013, 11:52 AM Thread Starter
mtidwell
Not a big deal really,, just asking
Yes ,, pull the head with the manifolds attached.
Obviously replacing the manifold gaskets would be easiser on the bench. Than with it in the engine bay.
For that matter , if just replacing only the head gasket may mot even need to do new manifold gaskets.
Just discussion?
I know most cases the head needs vked ,, but its a new rebuild ,, i believe a faulty install of the head gasket.
Thanks
The Fireman
mtidwell is offline
post #7 of 12 Old 04-30-2013, 04:46 PM
ROWA
ROWA's Avatar
If you're doing a head gasket why not replace the manifold gaskets at the same time.
I use a cardboard box, label it with an arrow pointing to the front, punch 16 small holes in it label 1-16 and when you remove the pushrods place them in the hole as you remove them from the engine.
Check the head for warping and burns on the top of the cylinder block from cylinder to cylinder.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #8 of 12 Old 04-30-2013, 07:42 PM
Old4X
1990 CJ7
You can pull it with the manifolds attached, but that is one heavy head stripped, the manifolds really make it awkward . And you do need to pull the pushrods.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #9 of 12 Old 04-30-2013, 10:48 PM Thread Starter
mtidwell
Thanks for the info guys ,, i am gonna do it soon ,, ill let u know.
The Fireman
mtidwell is offline
post #10 of 12 Old 05-02-2013, 04:50 AM Thread Starter
mtidwell
Ueah i pulled the push rods,no reason not to,,plus they will fall out anyway
Duno what he was thinkin
I did leave manifolds on. Much eaiser,, with Help!!!
The Fireman
mtidwell is offline
post #11 of 12 Old 05-02-2013, 02:42 PM
88RedWrangler
it's all a learning experience... just remember, read everything you can get your hands on and always ask questions. I've only had my jeep for a month or so but I will say, every question I had in my head, I found the answer here or on the wrangerforum. I'm no mechanic by any means but I've done my fair share of work and with the help on here, I've done WAY more than I ever thought I could. Take your time, label things, doublecheck your work and torque and you should be good to go.
Best of luck man!
post #12 of 12 Old 05-02-2013, 04:22 PM Thread Starter
mtidwell
Thanks,
All done went well.
I think its fixed,, well know this weekend for sure.
The Fireman
mtidwell is offline
