do CJ full doors fit on YJs? - JeepForum.com
post #1 of 20 Old 10-22-2008, 12:54 PM Thread Starter
cmcgover
just like it says anybody have any experience putting cj full steel doors on a yj? thanks.
1993 4.0 31's, 7in flares, highflow cat & flowmaster muffler ( all to pass inspection)
cmcgover is offline
post #2 of 20 Old 10-22-2008, 01:05 PM
muddy93
1987 FSJ Wagoneer
yes, they will fit. these are CJ doors on my 93 YJ.
the only isue you might have is if the CJ doors have the twist style handle, those require a different striker to be put on the jeep tub.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 20 Old 10-22-2008, 01:11 PM Thread Starter
cmcgover
nice, u think they would work with a yj hard top too? the reason is i have a guy selling yj doors for 500 and a cj guy selling his for 100. i could prolly get the strikers pretty easy from a yard.
cmcgover is offline
post #4 of 20 Old 10-22-2008, 01:14 PM
disarm6565
Yes, I run a YJ hardtop with CJ7 doors on my 1993. The only real difference in tops is the latch on the liftgate.
In fact, I'm fairly certain any YJ/CJ7 door/top system is completely interchangable.
1993 4.0 AX-15
disarm6565 is offline
post #5 of 20 Old 10-22-2008, 01:16 PM
disarm6565
Before I get slammed I mean all the door/top systems are interchangeable (excluding softops)
1993 4.0 AX-15
post #6 of 20 Old 10-22-2008, 01:19 PM Thread Starter
cmcgover
what year cj doors are u running? did you have to change the stricker? because im hearing from some people who did nothing but put the doors right on.
cmcgover is offline
post #7 of 20 Old 10-22-2008, 01:56 PM
muddy93
1987 FSJ Wagoneer
the doors I have on mine are 85 or 86.
as long as the have the paddle style handle, like in my picture in my post above, they will work with the YJ striker.
the only thing I had to do was adjust the hinges on one door to get it to line up correctly.
I don't remember wen the handles changed, but the earlyer CJ's had a twist handle, like this one, that will require a striker change,
and, yes, they will work with a YJ top. as already mentioned, the only difference between the CJ and YJ hard tops is how the rear glass closes with the tailgate. with the CJ tops, you had to open the glass first, then the tailgate. with the YJ tops, the tailgate has to be opened first.
muddy93 is offline
post #8 of 20 Old 10-22-2008, 01:58 PM Thread Starter
cmcgover
muddy when you adjusted the hinge did you have to drill new holes for it, or was it easy
cmcgover is offline
post #9 of 20 Old 10-22-2008, 02:05 PM
Chuiso
1996 YJ Wrangler
Im sure you have not problems but you have to ajust
Chuiso is offline
post #10 of 20 Old 10-22-2008, 02:08 PM
muddy93
1987 FSJ Wagoneer
no need to drill holes. just loosten the bolts, align the door, tighten the bolts.
there is quite a bit of adjustability in just the door hinges. however, on the off chance that there isn't enough, you can also loosten the body side of the hinge, and adjust it as well.
muddy93 is offline
post #11 of 20 Old 10-22-2008, 02:14 PM Thread Starter
cmcgover
alot of help. thank you
cmcgover is offline
post #12 of 20 Old 10-22-2008, 02:35 PM
disarm6565
I want to say the door latch changeover was in 1983. I think the 1981 had the older style striker and handle. And to be honest I dont know if they even made a CJ in 1982 I've actually never heard of anyone owning one...kinda strange.
1993 4.0 AX-15
post #13 of 20 Old 10-22-2008, 02:47 PM
cmsurfer
Ditto on the above.. I have the early CJ doors on my '93 YJ. Got them for $100 Found a set of of NOS CJ strikers, put them in and the doors work perfect. They work fine with a YJ hardtop too.
Where are you in NJ?
cmsurfer is offline
post #14 of 20 Old 10-21-2010, 07:36 PM
birdie17
How can I make CJ doors fit on my 93 wrangler?
Specifically for cmsurfer....your situation sounds a lot like mine. I just bought a 93 wrangler off of craigslist, and the full doors that came with it are CJ doors (I believe the hard top is also from the CJ model). Unfortunately, the doors don't have any handles, so now I'm trying to find a way to make this work. Right now the doors just have holes where the handles are supposed to be....no mechanism on either side. Do you know what I need to make this work? Every place I've gone so far has told me they couldn't help, including a jeep junk yard. I'm pretty unfamiliar with jeep parts, so if you could send a link to a picture, that would be awesome!
Thanks!
birdie17 is offline
post #15 of 20 Old 10-21-2010, 08:03 PM
Nick_Knipp
1986 MJ Comanche
heres my question, i got a 95 YJ softop, and the windows are hell. are there any doors that dont have "zipper" windows and rather one u roll down. that will fit on my Jeep?
"Don't curse in your profile"
-The Moderators
'86 MJ XLS 4x4 2.8L 3spd longbed buckets
'12 MK Sport 2.4L AT rescue green
Nick_Knipp is offline
Half doors to full steel doors - '94 body, '88 doors xponce YJ Wrangler Technical Forum 8 02-20-2010 04:29 PM
Possible to replace soft-top half doors with full doors? laka YJ Wrangler Technical Forum 5 09-11-2006 04:24 PM
Question about Full Doors/Half Doors and Locks booyia TJ Wrangler Technical Forum 9 09-09-2005 02:21 PM
Soft top? full hard doors vs. half doors jgarden TJ Wrangler Technical Forum 8 10-17-2004 03:00 PM
A soft top compatible with full steel doors and full soft doors? 91yjmd YJ Wrangler Technical Forum 1 01-16-2004 11:30 PM
