DIY XJ front driveshaft shortening for use as rear CV driveshaft on YJ - Page 3 - JeepForum.com
post #31 of 44 Old 12-14-2009, 12:32 PM Thread Starter
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Originally Posted by cwbymt1973 View Post
ok so i am on the same page the driveshaft you are making is for the slip yoke eliminator kit
Yep, you got it right.
One of the popular reasons to go this route is the relatively inexpensive costs vs buy a new custom made CV from a driveline shop.
If done correctly, the XJ shaft cut down will work pretty well for most folks.
Joe Dillard is offline
post #32 of 44 Old 12-14-2009, 12:40 PM
cwbymt1973
did you use a arc welder or a mig/flux welder as i have a lincoln hd 125 mig.
thanks for the info
cwbymt1973 is offline
post #33 of 44 Old 12-14-2009, 12:57 PM Thread Starter
Joe Dillard
I used my 220V MillerMatic 175 MIG with a CO2/Argon mix tank.
Welder left - plasma cutter right. Plasma is a Miller Spectrum 625.
post #34 of 44 Old 12-14-2009, 02:39 PM
1992 renagade
As always Joe Thanks for the great write up & pictures. Now the wheels are turning in my head and I just found a XJ front shaft I forgot I had.
Neill
1992 black Renegade
4.0L 5spd. 4:10 gears 33x12.50 BFG KM 2's A to Z fabrication front and rear bumpers and cage
1994 YJ Sahara Project Bean
2000 Jeep Cherokee Stock
AtoZ Fabrications
Blue Mountain Jeep Alliance
Delaware jeep Association
Screw the HOA. More guys just need to start doing man things in the garage.
Originally Posted by aw12345 View Post
Jeeps are like mistresses, they take all your money, but boy what a ride!
1992 renagade is online now
post #35 of 44 Old 01-08-2010, 09:07 AM
jashbrook
1980 CJ7
Nevermind.
jashbrook is offline
post #36 of 44 Old 01-08-2010, 09:14 AM
jbolty
jbolty's Avatar
Here's some SYE info. Make sure to shop around.
AA Slip Yoke Eliminator for the Jeep NP231 Transfer Case
Advance Adapters 50-7906 - Advanced Adapters Drive Shaft Angle Reduction (Slip Yoke Eliminator) Kit for NP231 Transfer Case - Quadratec
The purpose is to allow for using a longer drive shaft, which helps with decreasing the angle.
jbolty is offline
post #37 of 44 Old 01-08-2010, 12:05 PM
Tooch
just my kit in. cheap too. PORC
--NJ Jeeper--
like house music? join the crowd!
Green 4.0 5spd 4.10's, 4"rc lift, 33x12.50 bfg km2's
Tooch is offline
post #38 of 44 Old 01-08-2010, 01:20 PM
timatoe
timatoe's Avatar
Just wondering, what brand is that kit.
timatoe is offline
post #39 of 44 Old 01-21-2013, 11:52 AM
mudsweatNgearz
1987 YJ Wrangler
tag
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #40 of 44 Old 01-23-2013, 09:25 PM
theblackjeep98
Subd
UNCC MECHANICAL ENGINEERING TECHNOLOGY
MY JEEPS
98 TJ "mac" (5.2L v8 on 33's)
(Sold) 67 CJ5 "sheldon"
theblackjeep98 is offline
post #41 of 44 Old 01-23-2013, 09:33 PM
theskidkid
I hear and see so many people call it a cv driveshaft when, correct me if I'm wrong, but isn't that transfer case end called a dc joint (double cardon)? I just want to make sure i havrnt been calling the wrong joint the wrong name this whole time, thanks!
theskidkid is offline
post #42 of 44 Old 01-23-2013, 10:00 PM
SeanB95YJ
you're right AND wrong
a double cardan joint is a TYPE of CV joint... CV stands for constant velocity
there's double cardan, birfield (sp?) and I think one or two other types
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #43 of 44 Old 08-12-2014, 01:08 PM
Jeepsr4me
I need to mark this...
Jeepsr4me is offline
post #44 of 44 Old 08-12-2014, 07:53 PM
shrek91
I'll have to keep this in mind!
shrek91 is offline
Driveshaft shortening near Medina OH pmccoy9876 Wrangler General Discussion 3 12-01-2008 07:34 PM
front driveshaft in the rear? timritchieblue TJ Wrangler Technical Forum 7 11-21-2008 04:30 PM
Shortening Driveshaft Matt87YJ YJ Wrangler Technical Forum 5 04-19-2007 06:04 AM
8.8 install, driveshaft shortening headkase YJ Wrangler Technical Forum 22 12-16-2005 06:03 AM
XJ front CV driveshaft in rear after SYE Poppy360 TJ Wrangler Technical Forum 1 09-09-2004 12:33 PM
