-   -   DIY XJ front driveshaft shortening for use as rear CV driveshaft on YJ (http://www.jeepforum.com/forum/f12/diy-xj-front-driveshaft-shortening-use-rear-cv-driveshaft-yj-923331/)
Joe Dillard 12-11-2009 12:39 PM
There seems to be some interest on how to do this yourself. While I don’t proclaim to be a pro or know every option possible as far as going about it. I do feel that some folks who may have wanted to do this will have a little better insight as to one way on how to go about it as I try to explain.
First off – there are several ways to skin this cat. You can take the time & effort to cut off the drive shaft caps & retube it. However, for this example, I decided I’d use another effective method that gets good results and is less time consuming. Simply cutting the tube down & removing a portion of it & sleeving it is another nice way of performing this task.
Anyway, after you have went to your local junkyard & acquired a front XJ driveshaft in reasonably good condition, you’ll want to give it a good comb-over to see if there are any hidden damages that you didn’t first discover or worn parts to swap out.
If you deem it to be in good condition, you’ll want to crawl under your Jeep to take a careful measurement from the rear differential yoke where the center of the ujoint cap will be, to the yoke of the tcase where the center of it’s ujoint cap will be.
In the case of the one I’m showing here – it was going on a friends YJ who I recently installed a RC 4” lift kit, and other friends of his helped him install a Ford 8.8 rear axle from out of an Explorer.
My measurement showed that it needed to be 16.25” long in the static position.
A couple items to consider are:
How much slip does the XJ shaft have available (in this case ~4”)
Does the current suspension set-up allow for enough spline contact when under compression & rebound – for a 4” slip drive shaft.
If you have a suspension that requires a long slip drive shaft – this mod may not meet your rear driveshaft needs/requirements.
With these tid-bits of information in my hip pocket, I took the XJ shaft & placed it in my chop saw so that I could make two cuts, and removed a section long enough so that when the driveshaft was butted back together, and the spline contact was near the 2/3rds mark, the drive shaft would be 16.25” in length.
My plans are to sleeve (not retube) the drive shaft. Knowing this, I needed to know the diameter of the drive shaft – which happened to be 2.5” OD (outer diameter).
So, my sleeve material needed to be 2.5” ID (inner diameter) and I chose material ¼” thick. So that made my sleeve material 2.5” ID x 3” OD. Yea, overkill, but I wanted this to be a non-issue & add some beef.
I wanted to use DOM tubing for the sleeve, but my garage supply was out, and my local steel supple shop was fresh out of 2.5” ID x 3” OD tubing too. So, instead….I went with some 4130 chromo tube. Yea, a bit expensive, but I needed to complete this job today & my friend didn’t need much tube. I purchased ~2’ and he needed only ~3” of it. I kept the rest so that I could resleeve several others in upcoming days.
To my slight surprise, with a brand new wheel on my chop saw, and after ~10-15 minutes, this is as far as we got attempting to cut the 4130 chromo tube. :laugh:
http://www.fototime.com/998C03DB181F4D4/standard.jpg
At that point I decided to give my plasma cutter a shot – knowing it would slice thru the tube like a hot knife thru butter. After this was done, I cleaned up the end that I cut with my bench grinder. I also removed a factory balance weight from the drive shaft. I did so by using a chisel & hammer.
I ended up using a 3” piece of the chromo tube for sleeve material.
Here’s what the short end of the drive shaft looked like with the 3” piece of sleeve slide over the one end. As you can see by the internally welded seam, the original XJ shaft is made from HREW.
http://www.fototime.com/E275CD7BC2F3BE8/standard.jpg
http://www.fototime.com/280903AB9B76678/standard.jpg
Here’s the shaft butted together with the sleeve inplace. We also replaced one of the ujoints since it was showing signs of age.
http://www.fototime.com/8BF337F2C38F64C/standard.jpg
http://www.fototime.com/8258463C3FF6A94/standard.jpg
http://www.fototime.com/78915200A33B29C/standard.jpg
http://www.fototime.com/966CBEA7BA8FABC/standard.jpg
Here, I’m getting ready to weld it. Since the sleeve is chromo & the XJ tube is HREW, I heated up the metals to help prevent getting a poor weld. After preheat – I used my trusty MillerMatic 175 MIG & CO2/Argon mix tank to do the welding duties. I started off with some tact welds then came back & ran several ~1.5” long beads.
http://www.fototime.com/78E463FCA757B95/standard.jpg
After allowing it to slowly cool, Nate & I taped up the shaft & rattle canned it with some Rustoleum primer & then black spray paint.
http://www.fototime.com/950F7A06333F5DC/standard.jpg
Watching paint dry. :laugh:
http://www.fototime.com/D89C24698214D33/standard.jpg
Well, that’s about it except the easy install.
95jy 12-11-2009 01:25 PM
thanks great thread i will try that when i get home fgor vacation does this take place of the sye
1997_Sport 12-11-2009 01:26 PM
Did you install the SYE kit before measuring? Also wow, good work Joe :cheers2: Way to much for me to tackle though. haha
timatoe 12-11-2009 01:32 PM
You'll have to have the SYE installed to get an accurate measurement.
1997_Sport 12-11-2009 01:34 PM
Ok thats what I was told and thought, I was just hoping to save some time.
Joe Dillard 12-11-2009 01:38 PM
Nate had already installed an SYE but still needed a CV driveshaft. So this relatively inexpensive mod was the solution for a driveshaft.
Joe Dillard 12-11-2009 01:39 PM
Yep, an SYE went in first - sorry I didn't mention that.
It's really fairly easy as long as you have something to cut the tube & weld in the sleeve.
95jy 12-11-2009 01:39 PM
so you need the sye thanks man
1bad92yj 12-11-2009 01:58 PM
So how much did it end up costing in the end?
jbolty 12-11-2009 02:04 PM
The drive shaft cost about $15-$20 from the junk yard.
autoboy454 12-11-2009 02:07 PM
Thanks for the write-up! Exactly what I was looking for! Now how balanced do you think the shaft is after cutting/sleeving/welding it back together? Did you get it balanced?
Joe Dillard 12-11-2009 02:33 PM
Like jbolty (Jeff) mentioned, it was Jeff who obtained the shaft from a local yard. Jeff (along with some other local Jeepers) were nice enough to help Nate install the 8.8 & SYE, plus Jeff donated the shaft.
Please understand and keep in mind - Nate is a local Marine Corp guy :salute: & we try to support our military folks as best we can. So as a token of our appreciation for his service - we do what we can to help him out.
Nate purchased 1 ujoint, and that's all. The rest was donated to him since he is a good friend.
But, if tallied together: driveshaft ~$20, ujoint ~$15, ~3" of 4130 chromo tubing ~$4, extra tape & paint I had laying around was basically free.
So all in all ~$40.
Nate & I gave it a run around my neighborhood after the install & all was good with only very minor vibes. Nate later had it professionally balanced. I don't know what that cost him.
1bad92yj 12-11-2009 02:53 PM
40 isnt to bad at all. Thanks for the write-up, it'll come in handy when I install a sye.
YJames90 12-11-2009 03:10 PM
Damn, They go for 80 around here
jbolty 12-11-2009 03:18 PM
lots of perfectly good vehicles get junked in california just because they can not pass smog check.
The time now is 05:14 AM.
