DIY tube fenders - JeepForum.com
post #1 of 38 Old 02-09-2011, 08:39 PM Thread Starter
'92 vegas YJ
DIY tube fenders
well i FINALLY got my fenders done so i figured i'd post it up and do a little write up.
I've wanted tube fenders for a while now seeing that everytime i go wheeling my tires are always STUFFED into my fenders and now my fenders are all cracked and out of shape. i know i should invest in some bumpstops, but what fun would that be. another reason i wanted to get some tubes was to get rid of the stupid bushwackers i put on when i was like 16 or 17.
so its decided, i should get some fenders. but what now? do i make some or buy some? well im cheap and i like to try to pretend i can fabricate. so i decided to make some. now i was in the same boat as everyone else "this would be so easy if i had a tube bender". originally i was going to order the prebent tubes from jeeptubes.com. then one day i figured i'd run to the local steel supplier and see how much it would be if i bought it myself and had it bent. well i was able to purchase all of the tube i needed for $20 and went to a local fab guy and he bent two 90 degree bends for me for $30. so i got it done locally and the same day for $30 cheaper than jeeptubes not including shipping. i spent another $20 on the flat plate for my sides.
for the tube i went with 1 1/2" .090" HREW and some 1/8" steel plate for the sides.
my big issue now was i wanted to use my stock inners, now how am i going to cut and chop up my fenders while still driving to work everyday? thats where having a 2nd jeep comes into play. i have a very nice looking '95 tub sitting in my garage that decided to lend me his fenders.
i started by chopping off all of the material i didnt need. i decided for now that im going to keep the sheetmetal top. i might switch to plate at a later date if i feel the need.
so over the next couple weekends whenever i had time i was out chopping up fenders and making the grill and tub mounts. i just used some flat plate i had laying around. i dont have any pics of this stage. forming the bend for the grill was easier than i thought. i just layed it against a brick and whacked it till it bent to where i wanted it.
after i did all that i could on my spare tub i decided that i need to make it to my '92 YJ's actual specifics. so late one fri night a friend and i started taking off my stock fenders.
this is what it looked like the next morning in the daylight.
i had a bunch of pictures from the mock up on the passenger side but somehow i lost them all when i tried to transfer them from my phone to the computer. im quit upset.
this is where my dad(came in town for the weekend) helped me mock up the driver and i tacked it in place
then i used the old tape trick to get my template to cut the plate for the side.
after i had everything mocked and tacked in place where i wanted it to be i pulled it apart and welded it.
i just tacked the top piece all the way around to the tube then ground it smooth and tacked some more
then i added a little gusset
once everything was all welded up i decided i'd try my hand at body work. BEWARE I HAVE NEVER DONE BODY WORK OR EVEN WORKED WITH BODY FILLER IN MY LIFE!!!!
i went and got some of this
and lots of this haha
using body filler really wasnt hard at all. im not gonna say im good at it but it wasnt hard. here is some of the body filler after i just applied it and waiting for it to cure
i applied it to both fenders and spent A LOT of time sanding. no joke i spent a couple good hrs trying to get everything all smooth. i eventually got tired of sanding and said screw it. they look good enought to go beat up on the trail.
'92 vegas YJ is online now
post #2 of 38 Old 02-09-2011, 08:42 PM Thread Starter
'92 vegas YJ
here they are side by side after the sanding
before paint i figured id do a last minute mock up and see if everything still fits after welding. to my surprise it all fit and there really wasnt much warping or anything
then i took them out back to my little paint booth. aka gazeebo hahaha. when its windy outside i wrap clear painters plastic around the outside of the gazeebo, throw a tarp on the ground, wear a respirator and wala i have a perfect paint booth. ive used it from everything from my quad frame to my rockers and now my fenders
after 3 coats of primer, 3 coats of white paint and a clear coat i think im ready to install
and thats how i made my tube fenders. sorry i dont have as many pictures as i wouldve liked but oh well.
at first i started by just doing a little at a time on the weekends and then the last 3 days straight ive spent all of the daylight on these bad boys.
i had to hurry up and get them finished as i leave on fri for king of the hammers.
im pretty content with them.
i took my rear bushwackers off and am debating on throwing on the tj flares i have(thanks again jeff) or just leaving it flareless with my s****y hack job i did a couple yrs ago until i get my rear corner armor.
it went from this
to this
-chris
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
post #3 of 38 Old 02-09-2011, 08:42 PM
Tenshots1
o your just going to stop there!!! i cant wait now!
1998 XJ Build:
Tenshots1 is offline
post #4 of 38 Old 02-09-2011, 08:55 PM
TheNewbie
+1
Don't leave us hanging.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #5 of 38 Old 02-09-2011, 09:02 PM
carlitos_90
acciddental but i have question what tubes did you buy? dont know anything about tubes lol so yeah
carlitos_90 is offline
post #6 of 38 Old 02-09-2011, 09:11 PM
McFatter
On mine I used a piece of c channel bolted to the tub to weld the bars to. I had to notch it to make it fit around the brake booster, but besides that it worded out pretty nice
McFatter is offline
post #7 of 38 Old 02-09-2011, 09:35 PM
McFatter
looks good! The bondo really cleaned them up nice
McFatter is offline
post #8 of 38 Old 02-09-2011, 09:38 PM Thread Starter
'92 vegas YJ
i just bought some 1 1/2" .090 hrew and had a local fab guy bend it for me
post #9 of 38 Old 02-09-2011, 09:40 PM Thread Starter
'92 vegas YJ
thank you. i think the bondo made a world of a difference. makes it look real clean and smooth
post #10 of 38 Old 02-09-2011, 10:45 PM
carlitos_90
were can i buy said tubes? are they heavier than stock fenders+fender flares or bit lighter?
post #11 of 38 Old 02-10-2011, 05:15 AM
grandboost98
thats it, this is my next project lol i was actually at home depot the other day checking out prices for HREW
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #12 of 38 Old 02-10-2011, 09:12 AM Thread Starter
'92 vegas YJ
i bought my tubes locally. you can either find a steel supplier near you or order it online. i would not suggest going to home depot or anything. i dont think they'll have what youre looking for, even if they did home depot charges and arm and a leg for metal.
i think your best option would be to order these. http://shop.jeeptubes.com/product.sc?productId=11&categoryId=8
keep in mind this project requires A LOT of grinding and cutting and measuring and welding. then more measuring and some beer to have your friends come over and hold the tubes up while you do more measing and leveling and tack welding.
the weight i would have to say is almost the same. they might be a bit heavier but nothing extreme. they still pick up easily one handed.
-chris
post #13 of 38 Old 02-10-2011, 09:13 AM
1222
RIP John
1222's Avatar
Nice job and I like the pics too. How close do your tires come now at full flex?
(2011-2016)
1222 is offline
post #14 of 38 Old 02-10-2011, 11:23 AM
newheep
looks great, I would have used a little thicker tube, more like .120 wall but thats just me.
newheep is offline
post #15 of 38 Old 02-10-2011, 11:45 AM Thread Starter
'92 vegas YJ
i thought about the .120 wall. thats actually what i went to go get originally but then i got to talking to the guy at the steel place and he made some good points that had already been in the back of my head. i want it to be strong but not strong enough that if i hit them hard all the pressure goes straight to my tub. hopefully with a little thinner wall tubing if i hit it hard enough the fenders will absorb the impact and dent or deform before my tub....
i could be wrong but id rather replace some tube on my fenders then my entire tub.
-chris
TNT tube fenders -vs- overkill eng tube fenders CCJ TJ Wrangler Technical Forum 44 12-02-2011 03:24 PM
Using tube fenders as replacment fenders? CDW_327 YJ Wrangler Technical Forum 9 01-26-2011 11:09 AM
about how much tube will i need for diy basic tube fenders??? nathan2034 YJ Wrangler Technical Forum 17 01-17-2010 05:12 PM
For those of you with tube fenders or chopped fenders....? wmeyer116 TJ Wrangler Technical Forum 4 11-01-2009 04:39 PM
new fenders or tube fenders?? cstamets TJ Wrangler Technical Forum 5 04-13-2009 10:08 PM
