DIY "Highline" Fender Write Up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > DIY "Highline" Fender Write Up
Poison spyder items @ oconee off road 706 534 9955FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 08-14-2011, 10:30 PM   #1
JamesHasler
Hi,
Recently I "high lined" my fenders and TJ flares to get some needed tire clearance for free. Worked great! Here's my write up. Hope it helps!
http://members.cox.net/rough-riders2...t_Fenders.html
Oh, and I have RE 4" extreme duty springs, 1" body lift and TJ flares.
James
JamesHasler is offline   Reply With Quote
Unread 08-15-2011, 05:31 AM   #2
grandboost98
great write up
89 Jeep Wrangler - 3.5" HD BDS lift and M.O.R.E. HD 5/8" booms on 33s
99 Jeep Cherokee - 2 door, 5" lift on 33" super swampers
72 Chevy Nova - build in progress
98 Pontiac Grand Prix GTP - too many mods to list::SOLD::
grandboost98 is offline   Reply With Quote
Unread 08-15-2011, 06:58 AM   #3
KLT88YJ
X2 on the write up! Definitely perked my curiosity...!!
KLT88YJ is offline   Reply With Quote
Unread 08-15-2011, 08:43 AM   #4
Que89YJ
I've got to put some on that I picked up. They are the xenon flares for a tj. I am going to defintely use your writeup. Thanks
Que89YJ is offline   Reply With Quote
Unread 08-15-2011, 09:28 AM   #5
JamesHasler
Yup, I have the Xenon TJ flares as well. Had them on for YEARS and they've held up great.
Also, let me know if anyone wants any pictures of the rear fenderwell. I trimmed A LOT! Basically, I trimmed until I couldn't trim anymore without cutting through to the interior of the tub. I did this in the front and top of the wheel well. In the front, the wheel well is angled back quite a bit. My 37's just clear. If you go bigger without adding a bump stop, you'd probably have to cut this part of the wheel well out and fab a new one.
In the rear of the rear wheel wells, there is a vertical, rectangular piece of sheetmetal that gets in the way of big tires moving back as the spring compresses. In this case, I cut some of the spot welds that attach it to the outer fender sheetmetal and pounded it back along the bottom. I retained it so it still protects the fuel fill lines on the drivers side....
James
Unread 08-15-2011, 05:34 PM   #6
JamesHasler
Perhaps I should have titled this thread "DIY stock front fender 'highline'", not to be confused with people building new highline tube fenders.
James
Unread 08-16-2011, 07:42 AM   #7
LrdJeffson
this is very slick...thanks for the write-up...
-dave
Life is hard. It's even harder if you're stupid!
LrdJeffson is offline   Reply With Quote
Unread 08-16-2011, 10:58 AM   #8
JamesHasler
-dave
Most people don't even realize the fenders and flares aren't in their stock location! Only a Jeep owner with a keen eye notices things like the rear flares being mounted so high and then try and figure out how the front matches... Very stealthy
Unread 08-16-2011, 11:11 AM   #9
buckedgabers1
Looks a bit strange the body lines on The tub don't line up any more looks half *** no offence just looks slopy
My junk is bigger than your junk
buckedgabers1 is offline   Reply With Quote
Unread 08-16-2011, 11:53 AM   #10
Que89YJ
Do you really think so buckedgabers? I thought it looked good. I am a little nervous about cutting away on the Jeep. I have the Zenon flares waiting to install. What would you do different?
Unread 08-16-2011, 01:56 PM   #11
Ronnie-Evans
I wanna see the rear! This is the way I'm heading exactly
I think most of us can all agree on Jeeps, zombies, bacon, beer, and big boobies.
Ronnie-Evans is offline   Reply With Quote
Unread 08-16-2011, 02:22 PM   #12
JamesHasler
Yeah, the TJ's have an additional body line that matches up with the hood when cut. But for me, the clearance is worth it...
Here's a pic zoomed in on the area in question. You can also see the door trim I used on the cut hood edge. (This pic is pre-monstaliner.)
I'll take some pics of the rear tonight and post them up...
James
Unread 08-16-2011, 02:27 PM   #13
JamesHasler
You can install the Xenon flares and get quite a bit more clearance without raising the fenders. I ran that way for years. Might be an option if you don't want to cut your hood...
James
Unread 08-17-2011, 03:25 PM   #14
TJRoberto
hello James
I have a TJ and I am planning on doing some homemade highline fenders like yours, can you send me your write up with plenty of pictures?
the link you have on the very top does not work
thanks
TJRoberto is offline   Reply With Quote
Unread 08-18-2011, 05:47 AM   #15
Que89YJ
X2 post up the writeup from the other web site you have linked and include the pics on the rear. I'm looking at doing mine and you really did a good job with it.
