DIY Gas tank skid plate help? - JeepForum.com
post #1 of 20 Old 08-02-2011, 07:09 PM Thread Starter
yjluv
I am looking to build a gas tank skid plate for my 95 YJ. I have done some searching on here but have had no luck so far. Could someone please help me out here? I am looking for dimensions also.
yjluv is offline
post #2 of 20 Old 08-02-2011, 10:02 PM
jbolty
jbolty's Avatar
like this?
http://www.4x4trax.net/GasSkid.htm
http://www.4x4trax.net/index.htm
jbolty is offline
post #3 of 20 Old 08-02-2011, 10:37 PM
Hghgrad
That link is awesome. Really takes the guess work out of building one!
Looks like I figured out what I'm working on next.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline
post #4 of 20 Old 08-02-2011, 11:26 PM
04WJny
1987 YJ Wrangler
Nice find. That link has some great stuff on it
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #5 of 20 Old 08-03-2011, 02:01 PM Thread Starter
yjluv
JBolty you are awesome. This is exactly what I was looking for. Thanks a million!
yjluv is offline
post #6 of 20 Old 08-04-2011, 06:41 AM
Que89YJ
I followed through to the rest of his web page. Damn! He has to be a fabricator of some kind. Now I have a bigger list of stuff I want to do withoout the talent to to do it! LOL
Que89YJ is offline
post #7 of 20 Old 08-04-2011, 07:16 AM
Spuznick242
Haha. Let me know how your build goes. I need to make one myself. I'm thinking 1/8 inch plate still cut and welded to fit around the tank with holes drilled.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #8 of 20 Old 08-04-2011, 07:33 AM
jbolty
jbolty's Avatar
Don't forget to tip your waitress.
That site has been around for a while, but at another location. It went away completely for a while so I would save off everything there now in case it disappears again.
jbolty is offline
post #9 of 20 Old 08-05-2011, 08:44 PM
mobility
Not to worry, that just happened because the original site was running of a PC at home. I lost the old domain (one of those free ones anyway) when I switched to a proper hosted service. Anyway, glad it helps.
mobility is offline
post #10 of 20 Old 08-05-2011, 11:59 PM
monkeyhouse
i think i tipped the busboy, lol.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #11 of 20 Old 08-06-2011, 07:43 AM
jbolty
jbolty's Avatar
Ha. The man himself.
Any new projects?
jbolty is offline
post #12 of 20 Old 08-06-2011, 01:01 PM
mobility
Any new projects?
Not many things I can think of to build for it now but open to suggestions.
The only things that come to mind are:
  • New oil pan skid if I change my down pipe to stock config.
  • A set of Safari doors maybe.
mobility is offline
post #13 of 20 Old 08-08-2011, 10:22 AM
Que89YJ
Mobility you the man. I love the fabbing and how well you documented it. I was going to build you tank skid and had the drawings without the demensions.
Que89YJ is offline
post #14 of 20 Old 11-14-2015, 11:37 AM
jrhoades
New to the Jeep Wrangler world and jeep forum looking to make a gas tank skid plate for my YJ just a winter / work vehicle. P O put gas tank in the back wanting to return it to original location. Any suggestions as the link no longer works.
jrhoades is offline
post #15 of 20 Old 11-14-2015, 12:39 PM
sptrmike
sptrmike's Avatar
Its a sticky on the first page at the top 4x4 TRAX
sptrmike is offline
How to take off gas tank skid plate LiveAndLearn TJ Wrangler Technical Forum 24 04-14-2015 04:03 PM
Do I need a gas tank skid plate? TyWebb04 TJ Wrangler Technical Forum 9 09-03-2009 01:00 PM
Gas tank skid plate help J13760 YJ Wrangler Technical Forum 1 04-13-2006 11:55 AM
TJ gas tank in a YJ skid plate?? David K. YJ Wrangler Technical Forum 0 05-11-2005 07:42 AM
Gas tank skid plate FastX YJ Wrangler Technical Forum 2 09-13-2002 06:52 AM
