Distributor shaft up and down movement - need help. - JeepForum.com
post #1 of 1 Old 04-17-2010, 10:37 PM Thread Starter
Justified
1987 YJ Wrangler
hey guys , been a long time since i have posted here..life got busy. anyways, i just pulled my cap on my 4.2L/258CID to check it's condition and noticed that the rotor is chewing it up! I pulled up on the dist shaft and found about 1/4 to 3/8" of play (up and down movement). i know this is bad, so a couple of q's here:
Is this a common problem with the 258?
has any one had any experience with this problem? if so details please...
thx guys. good to be back.
Justified is offline
Stuck Rotor Button on Distributor Shaft cdrymalla TJ Wrangler Technical Forum 1 12-06-2009 10:43 AM
Movement in the Steering Shaft sethkins88 TJ Wrangler Technical Forum 0 10-05-2009 06:25 PM
Movement. Too much? Red04X TJ Wrangler Technical Forum 2 05-27-2008 09:39 PM
output shaft movement F-BOMB YJ Wrangler Technical Forum 4 04-06-2008 12:22 AM
Distributor Shaft Testing 89YJWarrior YJ Wrangler Technical Forum 10 03-15-2007 06:40 PM
