Distributor problem - JeepForum.com
post #1 of 4 Old 06-16-2013, 07:26 PM Thread Starter
nikondsindent
Distributor problem
I seem to have a problem when it runs it sounds like I have a small random misfire and you can feel it PUFF out the tailpipe and when you unplug and cap the vacuum to the distributor it seams to run a bit smoother with almost non existing puffs. I have replaced cap rotor wires and plugs. Should I replace distributor or ignition coil???
nikondsindent is offline
post #2 of 4 Old 06-16-2013, 07:49 PM
Old4X
1990 CJ7
Hook up a vacuum gauge and see what it tells you. Check for vacuum leaks at the same time.
A compression test is also in order.
Replacing parts randomly is expensive.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 4 Old 06-16-2013, 08:33 PM Thread Starter
nikondsindent
Vacuum gauge to what? Where and what should i be looking for what is good what is bad?
post #4 of 4 Old 06-17-2013, 06:19 AM
Old4X
1990 CJ7
http://www.international-auto.com/fi...uum-gauges.cfm
Hook to manifold vacuum source
Old4X is offline
