Distributor issues ... - JeepForum.com
post #1 of 2 Old 04-08-2013, 06:44 AM Thread Starter
95yj0645
I just finished my 2.5 to 4.6 stroker swap using the existing harness .. Got it to fire on it's own for about 20 seconds then it wouldn't start and is way out of time. The dizzy actually wobbles while it's cranking. I got to cross referencing part numbers and I bought a 1995 wrangler distributor because the computer is a 1995. I just found out that the dizzy for a 1993 is different and that is what block I have from a 1993 Cherokee. What distributor do I need?
'95 YJ, 4.6L stroker, Ford 8.8, AX15, SYE, SOA, Cage kit, full armor, 35" MT/R Kevlar's
95yj0645 is offline
post #2 of 2 Old 04-08-2013, 10:53 AM
Que89YJ
The drive gear is the same. Get the entire assembly with the pickup sensor installed for about 90.00 or so. The bottom line is it doesn't matter which one as long as it is for the right size engine.
Que89YJ is offline
