distributor installation questions - JeepForum.com
post #1 of 16 Old 12-17-2005, 09:04 PM Thread Starter
Bot
So I need to put a distributor in my 4.2. The previous owner had taken it out. Is it as easy as sticking the new one in and screwing it down?
Anything need lined up?
2016 Rubicon Hard Rock JKU - ready for the mods
98 Sahara
2005 Rubicon
Bot is offline
post #2 of 16 Old 12-17-2005, 10:34 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
you have to align the dist correctly when cyl 1 is at TDC or your timing will be off.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #3 of 16 Old 12-18-2005, 10:08 AM
wolf3902
Yup, what Sentinal said. And maybe the oil pump too.
'93 YJ 2.5 Jasper; 5 speed
All stock, waiting to be reborn.
6/19/05 ...2" BDS suspension lift...the rebirth has begun!!!
ONE NATION, UNDER G O D
Support It, or Leave It!
wolf3902 is offline
post #4 of 16 Old 12-18-2005, 11:02 AM
Ovenman
After the #1 piston is at TDC, it pretty much pulls out, however you may need to twist it a slight bit to mesh the gears.
1990 YJ 4.2 Sahara, Automatic, 3.5" Lift, Toyo 31 AT, MC2150, HEI, Hardtop on for the winter.
_____
/l ,[____],
l---L 0lllllll0-
()_) ()_)--o-)_)
Ovenman is offline
post #5 of 16 Old 12-18-2005, 11:31 AM
yesterdaylight
not to be offtopic but ovenman check yer PM's!
Green Jeep Club Member #172
Low Output 4 Cylinder Jeep Club Member # 23
Green 1995 4 Banger
If only my pocket was as green as my Jeep :D
yesterdaylight is offline
post #6 of 16 Old 12-18-2005, 11:34 AM
Jeepfan Jeff
Jeepfan Jeff's Avatar
I just installed a new dist. I pulled the dist. cap exposing the rotor then manually turned the pullies untill the rotor was at a 90 degree angle to the block then pull it. I did need to use a long reg. screw driver to rotate the slot on the oil pump in order to insert the new dist. Put it all back together then firedit up a reset the timing. Be sure you put the rotor on your dist. before you stab it so you'll know it's in right.
90 YJ, 4.2, 5sp
3" rrrrrough ccccountry lift
custom f/r bumpers w/swingaway tire carrier
weber 551-38
nutered and juiced
Ramsey Pat. 9500
(5)33x12.50x15 wildcats
eagle alloys 058
Missouri Offraod Outfitters over the top axle truss
M.O.O. rock bruiser diff cover
bushwacker cut-out flairs
shrockworks rock sliders
sorry no pics of the Schrocks & Bushies yet(but soon)
personal garb.
Jeepfan Jeff is offline
post #7 of 16 Old 12-18-2005, 08:17 PM Thread Starter
Bot
should have the new dist. tomorrow. Sounds fairly easy but still makes me nervous as I haven't ever done something like this before.
I bought the jeep and the motor was missing the distributor and vavle cover. The valve cover is a no brainer but all the vacuum lines and air intake look like it might take some time to figure out how it all goes back together. Worse case scenario I will put a weber on it and forget about it
98 Sahara
2005 Rubicon
Bot is offline
post #8 of 16 Old 12-18-2005, 09:17 PM
jeeping.copm
Ive never heard of anything like this. How do you expect to start your car when your done if it hasnt had a valve cover on.
jeeping.copm is offline
post #9 of 16 Old 12-19-2005, 06:04 AM Thread Starter
Bot
Obviously i'm going to replace the valve cover before starting it. The valve cover and distributor were stripped for parts to get another motor running.
98 Sahara
2005 Rubicon
Bot is offline
post #10 of 16 Old 12-19-2005, 07:04 AM
wolf3902
Do you have a Haynes or Chiltons manual for it?
It should give you a step by step for the distributor.
As far as the vacuum lines...someone here with the same year and motor could maybe take some pics for you.
wolf3902 is offline
post #11 of 16 Old 12-19-2005, 11:30 AM Thread Starter
Bot
Yep I have a manual so I think I can figure it out...I hope. I'm pretty handy but this engine work makes me a little nervous.
98 Sahara
2005 Rubicon
Bot is offline
post #12 of 16 Old 12-19-2005, 11:52 AM
Doublehead
Doublehead's Avatar
Are you installing the stock distributor? Have you considered doing a HEI conversion, I just did it and I'm lovin' it
Doublehead is offline
post #13 of 16 Old 12-19-2005, 12:01 PM Thread Starter
Bot
I really hadn't looked at any aftermarket stuff. What are the benefits of the HEI?
98 Sahara
2005 Rubicon
Bot is offline
post #14 of 16 Old 12-19-2005, 12:18 PM
sentinal02
sentinal02's Avatar
an engine that runs much better. seriously the HEI upgrade is probably the best mod you can do to the 4.2 short of a FI conversion.
post #15 of 16 Old 12-19-2005, 01:06 PM
surfcapt
I am trying to find a HEI dist. Used $75.00 with no gaurantee. Seems like to much $. Any news ones out there or used with gaurantee?
surfcapt is offline
Seat installation Questions shockwavetj01 TJ Wrangler Technical Forum 0 10-29-2008 06:09 PM
Soundbar installation questions Jay Schrader TJ Wrangler Technical Forum 2 06-24-2006 06:39 AM
RE 2.5 Std Installation Questions jonner YJ Wrangler Technical Forum 9 05-09-2006 02:14 PM
Took hook installation questions mrparrothead TJ Wrangler Technical Forum 9 06-25-2004 01:28 PM
Replace a top installation questions??? cygnus3978 TJ Wrangler Technical Forum 8 02-03-2003 07:41 AM
