distributor - JeepForum.com
post #1 of 4 Old 11-07-2012, 12:58 PM Thread Starter
jeep16
distributor
what distributor should i run with my nutter bypass? any experience/stories? thanks
jeep16 is offline
post #2 of 4 Old 11-07-2012, 01:26 PM
Jax89Jeeper
A CRT HEI setup is the best IMO. By installing the HEI you will complete both the nutter and upgrade your ignition all in one step.
Jax89Jeeper is offline
post #3 of 4 Old 11-07-2012, 04:58 PM
mudsweatNgearz
1987 YJ Wrangler
What he said!
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #4 of 4 Old 11-09-2012, 09:25 AM
90DesertTanYJ
Yeah you have two choices really. Go with a one wire GM style HEI or revert back to an old point style distributor. When you do the Nutter you are essentially going back to the pre HEI days but still have the ICM and a newer style distributor that has different advance curves. You can change the curves by adjusting the advance weights. Do more searching here for procedures.
90DesertTanYJ is offline
