Disk Brake pad size problem. - JeepForum.com
post #1 of 7 Old 01-11-2014, 07:29 AM Thread Starter
WDNewman
Just finished putting new front brake pads on my '89 YJ. Driver side, no problem. On the passenger side the outer pad went on fine, but the inside pad would not fit. Upon further checking I found that the mounting plate was the same on all four pads, but the old pad for the inside passenger side was smaller than the pads for the other three wheels. Not the mounting plate, just the pad. This is a head scratcher to me. Has some PO during the last 25 years replaced the right side of the front axle with a different unit, or was there at one time different sized pads for the inner and outer applications? Any help will be appreciated.
WDNewman is offline
post #2 of 7 Old 01-11-2014, 07:36 AM
1320yj
The inner pads are different on some models because of the use of different pistons in the caliper. Steel pistons hace a larger clip and phenolic(plastic) pistons have a smaller clip. Take one of the old inboard pads to the parts store and they can figure out which pads you need.
1320yj is offline
post #3 of 7 Old 01-11-2014, 07:44 AM
Mark05059
someone probably changed the caliper with what is called a loaded caliper (meaning it came with brake pads installed)
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 7 Old 01-12-2014, 04:12 PM Thread Starter
WDNewman
Thanks guys. Either answer makes perfect sense to me. I'll take the old pad to the store this week to see if I can get a matchup. Was kind of strange to run into this situation, but over 25 years of "repair" I guess anything can happen.
Thanks again.
WDNewman is offline
post #5 of 7 Old 01-13-2014, 09:45 AM
jokerchief462
There is a remarkable difference between 89 and somewhere in the 90s for steering knuckles and brakes. PO may have replaced the right front parts.
You will be best doing show and tell at the parts counter.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #6 of 7 Old 01-15-2014, 06:21 AM Thread Starter
WDNewman
I tend to think that something indeed had happened to the right front wheel assembly in the recent past. The cotter pin on the nut of the right front wheel bearings was new. The left side wasn't. The existing pads on the left side were about 1/2 worn out, the ones on the right side were completely worn out with damage done to the rotor by the rivets. The left side rotor was by no means new, but the surface was smooth. I am starting to envision say, stump damage to the right front wheel (stumps are what we bang our jeeps into down here since we don't have rocks) and some PO getting a wheel assembly from a junk yard off of an older unit and installing the whole shooting match, worn pads and all.
Again, thanks for the help. Soon I will bother the devil out of some poor clerk at the parts store about this.
WDNewman is offline
post #7 of 7 Old 01-15-2014, 06:39 AM
Mark05059
what part number did they give you? There are 2 different sets by what year it is. d203 or d477. Im sure if you take your old pad in they will be able to fix you up. Once you buy this set hang on to what you have left over for when the pads you just put on wore out.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
disk brakes
