disc brake conversion - JeepForum.com
post #1 of 4 Old 03-02-2002, 12:43 AM Thread Starter
JYRUS
rear scout11 d44 disc brake conv. in a yj. any help. pricing, parts, etc...
JYRUS is offline
post #2 of 4 Old 03-03-2002, 09:48 PM Thread Starter
JYRUS
osburn, any help?
JYRUS is offline
post #3 of 4 Old 03-04-2002, 05:32 PM
Tailgummer
JYRUS, You will run into several problems including the different bolt patterns, which drive different axles, which mean different rear wheels. Now you have different patterns and wheels front to rear. Also the backing plate bolt pattern is probably different than what your YJ has. Probably easier and cheaper to buy the kit for the YJ. Another option is to swap to the Ford Explorer 8.8" from a '96 or newer. Already has the rear disc and is a simple swap. Also much stronger than the D35.
All the above assumes you have the stock D35 still. If not, disregard and accept my apology.
Good Luck
Chuck
'91 YJ, 4.0L 5sp, Atlas II, RE SOA + 2"BDS, 35" Explorer Xterrains, ARB's & 4.56 gears, WARN 9000i
WWW.4x4xnorthwest.com
Tailgummer is offline
post #4 of 4 Old 03-04-2002, 08:42 PM Thread Starter
JYRUS
no, i am swapping the scout d44 in and the flanges have already been redrilled to 5 on 4 1/2 from 5on 5 1/2. i just need the swap for the scout axle
JYRUS is offline
Big Brake Vs Disc Conversion Billyjon1 TJ Wrangler Technical Forum 4 09-25-2008 06:04 AM
disc brake conversion natehate TJ Wrangler Technical Forum 7 01-08-2007 02:07 PM
Who's done a Disc Brake conversion... archdlux TJ Wrangler Technical Forum 16 09-12-2006 06:55 PM
Disc Brake conversion on a D35 ED() TJ Wrangler Technical Forum 4 07-23-2005 01:30 PM
disc brake conversion jeep_olllllo_ TJ Wrangler Technical Forum 2 08-07-2003 06:50 PM
