Dirty Transfer case Fluid Just changed-leaking from Manual Transmission??? - JeepForum.com
post #1 of 6 Old 11-23-2008, 09:33 PM Thread Starter
ctsvmongo
Help me please. I am new to Jeep ownership. I have a 92 Wrangler 4.0 5 Speed Manual.
ctsvmongo is offline
post #2 of 6 Old 11-24-2008, 08:08 AM
idaholtby
Your ATF fluid turned dark so quickly because the inside of your newly acquired transfer case had a lot of dirt/sludge in it. Drain and refill the case with fresh ATF. Run it for a couple hundred miles and drain and refill again. Repeat until the transfer case fluid stays clean. ATF is a real good cleaner and it is dissolving the gunk that is in there. It is either repeated flushing, or tear it down and do a full rebuild/clean. As far as the tranny and transfer case fluids mixing, it is highly unlikely. Both units have their own seals and if either were to leak, it would gravity drain through a weep hole at the bottom and not make it between units.
Like you discovered, the transfer case tail shaft seal is a common leaker. You can replace it and clean/deburr your slip yoke for a semi-permanent fix. By design it will eventually leak again. Permanent fix would be to do a SYE conversion, but these are spendy.
As far as the tranny fluid, stick with GL-4 gear lube. GL-5's have sulfur additives that attack the brass synchros.
Being that you are in Nebraska, I would recommend a synthetic such as Redline MT-90 or Penzoil Synchromesh. These type fluids greatly reduce the stiff shifting in cold weather that these transmissions are known for.
idaholtby is offline
post #3 of 6 Old 11-24-2008, 11:25 AM Thread Starter
ctsvmongo
Thanks for the help. I can use that if I ever have any problems.
post #4 of 6 Old 11-24-2008, 01:42 PM
idaholtby
It is worth a try. The worst thing that could happen is that it still leaks and you are only out your time.
post #5 of 6 Old 11-24-2008, 02:25 PM Thread Starter
ctsvmongo
Thanks again, Nice Jeep by the way. Love the Hellcats(?)
post #6 of 6 Old 01-23-2009, 07:44 AM
crzylgzz
2011 JK Wrangler
wait wanna run that part about the tranny fluid by me again. Ive been wanting to drain and replace my manual tranny fluid for some time but> i havent the foggiest idea how...
So your saying the stock recommended fluid normally used is no good, cause it has a tendency to eat away at the brass synchro's..
ok where do i begin on the dump and pump?? I looked everywhere for a drain, fill plug on my tranny, no luck..
please advise.
crzylgzz is offline
Transfer case fluid still leaking jaycal3 YJ Wrangler Technical Forum 4 06-25-2009 09:45 AM
Differentials, Transfer case, Manual Trans. fluid change? 05jeepkj TJ Wrangler Technical Forum 12 02-12-2009 05:00 AM
Never changed diff and transfer case fluid WittSmall TJ Wrangler Technical Forum 13 02-07-2007 05:17 AM
'04: Manual Tranny/ Transfer Case Fluid (+4?) mkuzmukerau TJ Wrangler Technical Forum 7 02-11-2005 08:22 PM
Transmission Fluid, Diff Fluid, and Transfer Case markdonnell1975 TJ Wrangler Technical Forum 3 05-27-2004 01:27 PM
