dirtworx bumper and tire carrier - JeepForum.com
post #1 of 18 Old 12-21-2013, 01:49 PM Thread Starter
dukeryder
I've read a few reviews on this bumper/tire carrier combo on here, but I think most of those are pretty old.
It took a long time for it to arrive, but it is fabbed from raw steel to order, and I knew that and if I wanted one fast I could've order a made in china one for about the same cost. But this one is built so much better. It does come in raw steel so you have to either get it painted or powder coated. I opted to paint it myself since my Jeep is a trail rig and it's going to probably hit some rocks and stuff so I painted it with some Rustoleum "Hammered" for a fraction of the price.
It was really easy to install and everything lined up perfectly. I haven't been able to trail test it yet, and won't be able to until spring. But overall I'm much happier I went with this over a $hittybilt or the like.
dukeryder is offline
post #2 of 18 Old 12-21-2013, 02:18 PM
Richard_
is the bumper tow rated ? looks nice
Richard_ is offline
post #3 of 18 Old 12-21-2013, 03:13 PM
idskot
Well, considering how it's made out of solid steel, has those tow hooks, I'm guessing yes.
idskot is offline
post #4 of 18 Old 12-21-2013, 05:20 PM
Reno72
Have had mine for awhile, solid as the day I mounted it. No rattles, swing opens very smooth, I also ordered the high lift jack mount, it holds my jack and shovel. Only mod I did on mine was a wheel spacer as with my 35" tires and rim I didn't feel there were enough threads on the wheel studs. This moved my tire out a bit so it just touches the bars.
BTW it is rated as a class III hitch unlike many of the eBay bumpers which say "not for towing"
Reno72 is offline
post #5 of 18 Old 12-21-2013, 05:21 PM
Kdeome
That would be a stupid guess then.
Kdeome is offline
post #6 of 18 Old 12-21-2013, 05:51 PM
imstillatwork
safe to assume that MOST of the small fab shop bumpers are NOT rated for towing. To officially have a tow rating of xx,000 lbs costs a ridiculous amount of money.
If the hitch receiver is welded all the way through front and back, and the bumper is tied into the frame, I would tow a few thousand pounds with it. I have the dirtworx front bumper. If the rear is the same quality and the hitch goes through I'd feel very confident in its capacity to tow. Anything over a quad or two I'd make sure to get the frame tie in brackets from whoever it is that makes them.
imstillatwork is offline
post #7 of 18 Old 12-21-2013, 06:23 PM
dancytron
I have a dirtworx rear bumper. When I asked if it was tow rated, the answer I got was "officially no".
dancytron is offline
post #8 of 18 Old 12-21-2013, 08:12 PM
imstillatwork
Right, because officially it has to go through engineering, certification, and testing, and the manufacture then has to deal with liability and insurance. They have to say no to save their butt.
The materials and construction of these are better than the thin angle iron add-on hitches.
My only concern would be with frame tie in. The rear bumper plate is pretty thin on a YJ.
post #9 of 18 Old 12-21-2013, 10:33 PM
linusb
Looks great! I bought his hardware kit and I've been very pleased. The latch is very secure and functional.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #10 of 18 Old 12-21-2013, 10:46 PM
AtTheHelm
So much better than a mass produced bumper ordered from a catalog!
AtTheHelm is offline
post #11 of 18 Old 12-21-2013, 11:46 PM Thread Starter
dukeryder
It not only bolts to where the bumperettes used to be, but bolts to the frame as well.
This bumper could tow more weight than I'd ever want to tow with the YJ.
post #12 of 18 Old 12-22-2013, 03:24 AM
fratis
fratis's Avatar
So basically if you decide to tow with it and it fails, then no pointing fingers no matter what the consequences.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #13 of 18 Old 12-22-2013, 07:34 AM
jeepguy85
1987 YJ Wrangler
Originally Posted by dukeryder
I've read a few reviews on this bumper/tire carrier combo on here, but I think most of those are pretty old. It took a long time for it to arrive, but it is fabbed from raw steel to order, and I knew that and if I wanted one fast I could've order a made in china one for about the same cost. But this one is built so much better. It does come in raw steel so you have to either get it painted or powder coated. I opted to paint it myself since my Jeep is a trail rig and it's going to probably hit some rocks and stuff so I painted it with some Rustoleum "Hammered" for a fraction of the price. It was really easy to install and everything lined up perfectly. I haven't been able to trail test it yet, and won't be able to until spring. But overall I'm much happier I went with this over a $hittybilt or the like.
If you don't mind me asking, how much was that setup?
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #14 of 18 Old 12-22-2013, 12:13 PM Thread Starter
dukeryder
I paid $436 to have it shipped to my door, I think you can get it cheaper if you opt to not have the Hi-Lift Jack Mount or provisions for shackles IIRC that was like $100 less. (You can't see the Hi-Lift Mount in mine because I don't have a hi-lift yet and the tire is blocking it).
http://www.thedirtworx.com/Rearbumpers.html
post #15 of 18 Old 12-22-2013, 02:54 PM
Bong_Holyeo
I bought one of these for my jeep a year ago and it is as nice and solid now as the day i bought it. As far as the hitch, when using it to tow the YJ suspension and brakes are the weak link before the hitch. Some of the best money i ever spent on my jeep, i would also highly recommend dirtworx over $hitttybuilt any day.
Bong_Holyeo is offline
