Direct me to a dana 44 fact sheet please - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Direct me to a dana 44 fact sheet please
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955
Unread 09-02-2014, 03:44 PM   #1
Bighaydn
Alright so I picked up a dana 44 from an old waggy but I've got no clue what year it came outta. I'd like to know so I get can the right parts etc. before I put it in my yj. anyways it's driver side drop disc breaks, vaccume 4wd 6 lug and the gear ratio is 2.73 or somewhere right in there. Any idea what it came from? I'm think early 80s. Thanks
Bighaydn is offline   Reply With Quote
Unread 09-02-2014, 03:56 PM   #2
TSEJEEPERS
http://77cj.littlekeylime.com/web_rs44.html
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is online now   Reply With Quote
Unread 09-02-2014, 10:49 PM   #3
Bighaydn
Thank you
Unread 09-03-2014, 02:52 AM   #4
Drednot
Some times the manufacture date is stamped in the ring gear. Narrows it down to within a few months usually.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote
Unread 09-05-2014, 10:33 AM   #5
Bighaydn
What kinda numbers should I be looking for?
Unread 09-08-2014, 03:04 PM   #6
instg8tor
I believe the late 80's to 82 and some 83's had the vacuum disconnect in the axle. that should give you a starting point for the year.
'91 Renegade - Waggy 44/20 (F/R Aussie) SOA, E350 MC, York OBA, Custom F/R bumpers
instg8tor is offline   Reply With Quote
Unread 09-09-2014, 02:53 AM   #7
Drednot
My old CJ had a manufacture date of 8/74 and this gear set dated 7/8/74
This YJ had a vehicle manufacture date of 06/26/91 so I interpret the date on the ring as 5/29/91
So they are manufactured within a month of build
"Non Vi Sed, Arte"
Unread 09-13-2014, 04:43 PM   #8
Bighaydn
Thank you!
Unread 09-13-2014, 08:02 PM   #9
TSEJEEPERS
There should also be a number stamped on one of the axle tubes.
http://www2.dana.com/pdf/XGI.PDF
Unread 09-19-2014, 07:42 AM   #10
Bighaydn
The axle I got was an 82 but I feel like it had been sitting since 85 haha luckily it was full of heat oil when it was parked cause everything inside is in awesome condition but thanks!
Unread 09-19-2014, 02:28 PM   #11
Jeepsr4me
Most times on those DATEs you talking about. They are not days or months. Its a series number followed by year.
7th batch and run 8 with the year being 74..
They do this with tires too.
but it could very well be the date they machined it
It takes days to produce a batch and could be weeks before that batch is machined.
Jeepsr4me is offline   Reply With Quote
Unread Yesterday, 12:42 AM   #12
whiteyj1994
with tires it tells you the actual week and year of manufacture, first 2 numbers are the week (based on 52 per year) and the second 2 are the year.
lead foot locker and away we go
whiteyj1994 is offline   Reply With Quote
