diode on the alternator - JeepForum.com
post #1 of 9 Old 10-07-2009, 06:13 AM Thread Starter
Reverb
Hi all,
my Yj won't turn off after it's been running. I've put a switch inline to the power for the distributor/fuel pump so i can turn it off.
I've read that it's a common problem and i need to put a diode inline with the alternator.
Anyone know what size diode and where on the alternator??
Reverb is offline
post #2 of 9 Old 10-07-2009, 06:24 AM
Alfons
Originally Posted by Reverb View Post
Hi all,
The first thing I'd do would be to make sure the key switch was working - it it "cuts" the power, the engine should stop. A lot of things need a good steady source of DC power to keep the engine running (including the computer).
Alfons is offline
post #3 of 9 Old 10-07-2009, 06:37 AM
Que89YJ
Pull the asd relay and see if power drops. I just spent a week with Rebuild rookie troubleshooting the same type of problem. The question is wether power is going to the system through the relay or after the relay. Disconnecting the alternator will tell you if you need the diode or not. The diode stops the alternator field from back feeding. Do both and post back
Que89YJ is offline
post #4 of 9 Old 10-07-2009, 07:01 AM Thread Starter
Reverb
I'll give it a shot. Do I have an ASD relay on my 88 4.2?
Reverb is offline
post #5 of 9 Old 10-07-2009, 07:33 AM
Que89YJ
I didnt see that. Are you nuttered? Do the alternator first.
Que89YJ is offline
post #6 of 9 Old 10-07-2009, 08:04 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Hello
If you have a 4.2 your fuel pump is mechanical, I do not know what you mean by cutting power to the distributor, I guess you have tapped on the line that provides power to the coil, the distributor itself has no power, or maybe you interrupted the connection between the distributor and the ignition module.
You need to install this part
Radio Shack part number 276-1103.
There is a brown wire coming off the alternator, this is the battery charge wire, you need to install the diode to prevent the current from flowing back from the battery to the alternator, diodes have a "side" to them so make sure you install it the right way, you can test this with a multimeter and I know there are marks on each side but can't remember now what they look like, just use the leads of the multimeter to check for continuity, one on each side, when you get a good reading you know you have identified the flow direction.
I did this on my YJ when I installed my MSD ignition box, I do not know why a stock YJ would have this problem, the MSD runs on so little current that a few volts coming back from the battery to the alternator were enough to keep it running.
Use proper soldering when attaching the diode and when you are done cover everything in shrink wrap.
If you need help I can take a picture of the wire but later today when I get off work
Good luck!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #7 of 9 Old 10-07-2009, 10:07 AM Thread Starter
Reverb
Sorry I should have updated my profile - Currently running a HEI distributor and an electric fuel pump. I will get that diode and install it - I kinda like the kill switch I have in there so will probably leave that as an anti theft device.
thanks all for the help.
EDIT: 1A rating is enough for the diode?
Reverb is offline
post #8 of 9 Old 10-07-2009, 10:12 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
This is the part number recommended by MSD, should be fine, mine has worked flawlessly
Fernando is offline
post #9 of 9 Old 08-24-2013, 03:20 PM
superj
This diode fix works great on the 76 cj5 we bought two weeks ago. I know this thread is from many moons ago, the info is still relevant as the diode part number is the one I just bought and installed and now the cj turns off properly
I don't feel like working on anything at this time so i sold my yj.
superj is offline
Flat Tow Diode Wiring TJ LJ Weird Thing Axle71 TJ Wrangler Technical Forum 8 11-16-2009 01:25 PM
Anyone know where I can find this diode blamejane2 YJ Wrangler Technical Forum 20 04-29-2008 10:02 AM
Alternator?? bama27 TJ Wrangler Technical Forum 3 10-22-2007 09:44 AM
Alternator help!! ltdanyj YJ Wrangler Technical Forum 1 09-20-2007 09:04 PM
Alternator????? 2000wrangler TJ Wrangler Technical Forum 7 01-13-2005 08:47 AM
