Dimmer Switch Connector - JeepForum.com
post #1 of 1 Old 05-02-2010, 05:02 PM Thread Starter
LoneWolfUSMC
Does anyone know where I can get a "Dash Illumination rheostat" connector for a '90 YJ?
The previous owner chopped the connector off for whatever reason. I can get a replacement dimmer, but I don't know where to look for a connector.
I just need the connector with enough wiring hanging off so I can solder it back into the harness.
I have a feeling it's not going to be available from the dealer and the pull-a-part yards around here are notorious for not having the parts I need (although I will be calling around monday).
Hacked harnesses rate as one of the top reasons I hate other peoples projects.
LoneWolfUSMC is offline
Having problems with lights. Does the dimmer switch run through the headlight switch? spshultz YJ Wrangler Technical Forum 2 10-25-2009 06:43 AM
Dimmer Switch bella mia YJ Wrangler Technical Forum 0 09-28-2009 08:13 PM
HELP!!! Dimmer switch on 99 tj bradbodigon TJ Wrangler Technical Forum 5 12-08-2008 08:46 AM
Dimmer switch?? IH8ROADZ TJ Wrangler Technical Forum 3 03-22-2008 09:34 AM
dimmer switch help herde1724 YJ Wrangler Technical Forum 1 07-31-2006 11:01 PM
