Dimmer/Signal Selector Broke last night, need advice - JeepForum.com
post #1 of 6 Old 07-28-2010, 07:30 AM Thread Starter
computerguy
I am in the process of putting back together my '89 YJ from being painted and last night I drove it out of the garage last night for the first time since last October. I noticed the dimmer switch wouldn't click when I pulled back on the selector.....well when I got it back to the house it just fell off in my hand. The stalk had broken off inside of the plastic mechanism that is in the steering column. How do I go about fixing this? Do I need an entire upper steering column assembly? Any ideas? Thanks in advance for any help you can give!
computerguy is offline
post #2 of 6 Old 07-28-2010, 07:48 AM
Jeepsr4me
Just go to Autozone and get a new one.
Jeepsr4me is offline
post #3 of 6 Old 07-28-2010, 12:41 PM
KA24DET95
Here is a link on how to take the column apart. This is going to be your first step take it all apart and find out what all is broke.
Inside the GM tilt steering column - Pennock's Fiero Forum
I just went through mine about two months ago. I work at a shop so i get a pretty significant discount on parts so i bought all of mine at the dealer. I guess if Autozone has it you could buy the parts there but i would not recomend them to anyone but, thats just my opinion.
Good luck its really not that hard send me a message if you have any questions.
If guns cause crime, all of mine are defective.
KA24DET95 is offline
post #4 of 6 Old 07-28-2010, 04:34 PM
Mark05059
did just the handle break or is it the switch itself?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 6 Old 07-28-2010, 05:38 PM
disarm6565
If the handle isn't "broken" try just pressing it back in.
1993 4.0 AX-15
disarm6565 is offline
post #6 of 6 Old 07-29-2010, 07:14 AM Thread Starter
computerguy
No.........the handle itself broken. I going to take a small drill bit and drill into the piece still in the column, thread a long screw into it and try pulling it out tonight. I hope it works
Ac selector switch broke. Pls help bleep Wrangler General Discussion 6 02-10-2010 12:20 PM
4wd selector pops out of 4lo after installing RC 4in lift. Any advice? Arron TJ Wrangler Technical Forum 5 03-19-2009 02:14 PM
Little plastic vent selector arm broke off... danheit TJ Wrangler Technical Forum 13 06-12-2008 01:06 PM
turn signal broke randy33876 YJ Wrangler Technical Forum 1 10-02-2004 07:29 AM
turn signal rod and dimmer shaft lostboy YJ Wrangler Technical Forum 1 09-10-2003 03:42 PM
