Dim turn signal - JeepForum.com
post #1 of 2 Old 04-22-2010, 03:54 PM Thread Starter
cody11ca
Dim turn signal
93 wrangler 2.5L
I have had a constant issue with my brake lights and turn signals. I have replaced the multi function switch, and realized the the fuse was the issue. Now after replacing the fuse it blew again....I replaced it and now the right turn signal will not work and the hazards (which have always worked) are very dim on the right side compared to the left...
I switched bulbs and still a dim light on the right. What could be the issue?
93 yj, 2.5L, 33x12.5, 4inch lift, winch
Sacramento Jeepers Group #8
cody11ca is offline
post #2 of 2 Old 04-22-2010, 04:49 PM
czjeeper
Check the grounds at the light housings.
Sounds like you have some corrosion.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
Broken turn signal lever, Need to turn OFF hi-beams Tulsachokehold YJ Wrangler Technical Forum 16 12-10-2014 01:39 AM
New turn signal switch, no left signal? sasquachYJ YJ Wrangler Technical Forum 4 01-25-2010 10:07 PM
Driver side rear turn signal -- no signal --chris-- YJ Wrangler Technical Forum 5 02-23-2008 08:43 PM
Turn signal does not click off after completeing turn vr6mole TJ Wrangler Technical Forum 1 05-12-2007 10:49 PM
Turn signal to fast, brake/turn fuses blowing and a gas gauge with an identity chrisi pyro9862 YJ Wrangler Technical Forum 3 06-29-2005 02:35 PM
