Dilemma - JeepForum.com
post #1 of 3 Old 10-28-2010, 06:02 PM Thread Starter
Gilgameshwing
Dilemma
I have a YJ 1992, 4 cyl. 5 shift and I'm pretty much rebuilding the car one part at a time. So far the parts I've replaced are pretty small (starter and water pump) and it's time for the old engine to be fixed.
I have two options as far as I know: to get an entirely new engine (approx. $1200) or to get the old, original one rebuilt (approx $600).
So here is my question to you guys: Which would last longer?
(P.S. Keep in mind I don't know much about cars, so dumb it down. I catch on quick, but I know only basic terms)
Gilgameshwing is offline
post #2 of 3 Old 10-28-2010, 06:33 PM
jsawduste
2006 YJ Wrangler
Better to ask this question......
Is the new engine a factory engine ? Factory engines have a reputation of lasting many miles.
A rebuilt engine is only as good as the rebuilder. That is, the parts they used and who/how they rebuilt it.
IMHO a 600 dollar rebuild is not a full rebuild. Machine shop costs alone would reach more then 600 for boring, decking, crank grinding, head and valve work etc.
The other factor is simply how much you want to invest in your Jeep. Only you can answer that.
Believe it or not I have close to $6,000 in my stroker engine. But then little of it is factory Jeep.
This will be an entertaining thread.
jsawduste is offline
post #3 of 3 Old 10-28-2010, 07:05 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I don't know what labor rates are for you area. But parts are pretty much priced the same. There is no way you can even buy the parts to (properly) rebuild an engine with $600.00. Then there is the machine shop work and then the labor costs for removal and installation.
A $1200.00 rebuilt long block does not remove the old engine and install itself either. Then there is the costs associated with unknown conditions or the infamous 'might as wells'. You know 'you might as well' replace the alternator/radiator/starter/clutch& pressure plate or what ever else pops up or makes 'sense'.
My gut tells me that a $1200.00 long block will cost at least $2000.00minimum before you are finished since you are not doing most of the work.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
engine , rebuild , replace
New or Used JK dilemma justjeepinorfw JK Wrangler Technical Forum 26 03-03-2010 04:35 PM
My dilemma wonderboy TJ Wrangler Technical Forum 52 10-16-2007 08:27 PM
I've got a dilemma....TJ to LJ or not? Texan in Cali TJ Wrangler Technical Forum 38 02-04-2007 12:24 AM
My Dilemma JeeperAbe TJ Wrangler Technical Forum 7 10-22-2006 12:02 AM
Dilemma TJ-Tera TJ Wrangler Technical Forum 35 11-14-2005 08:56 AM
