Difficulty getting into first gear - JeepForum.com
post #1 of 3 Old 04-27-2010, 09:13 AM Thread Starter
Flingit1200s
2009 JK Wrangler
Just as the title says. It shifts normally through all of the other gears but when at a stop it is hard to get it into first. Where do I start?
"Rusty" is a 2009 JK, "X", 6spd, 2.5" Rock Krawler, Fox shocks, 33x12.5x15 Duratracs, AR Baja 15x8, Tuffy console, PIAA Fogs, 4:56 gears which are too low for this tire size, JCR front bumper, Warn winch.
Flingit1200s is offline
post #2 of 3 Old 04-27-2010, 09:18 AM
monkeyhouse
I would just check the master cylinder fluid level. It's a simple way to rule out a hydraulic issue. If the fluid is low, top it off, bleed it and check the level again. It could be alot of things, but a leaky slave or master can start out this way, if it's just a small leak. So, check it and make sure it's up to the line, take care of that if it's not and then post back here and someone will help you troubleshoot further.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #3 of 3 Old 04-27-2010, 09:28 AM
pasinbuy
Also check your tranny fluid. It does not take much of a splash to get water in your tranny. I found that one out myself. If the fluid is whitish vs. somewhat clear that means water.
pasinbuy is offline
SYE install... difficulty? bloke279 TJ Wrangler Technical Forum 15 07-13-2007 11:14 AM
Difficulty with even acceleration J.Bob TJ Wrangler Technical Forum 4 06-13-2007 11:09 PM
S.O.A. difficulty? libertyRubicon YJ Wrangler Technical Forum 7 07-20-2006 10:40 PM
Difficulty of an 8.8 Swap... Wheels4186 TJ Wrangler Technical Forum 1 03-23-2006 06:26 PM
mod difficulty longdecember YJ Wrangler Technical Forum 7 02-09-2006 04:01 PM
