Quantcast Differentials - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Differentials
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 12-17-2006, 06:05 PM   #1
MTGunNut
Differentials
what do use use, front and back? I am using open differentials (stock) but dont know what to put in.
MTGunNut is offline   Reply With Quote
Old 12-17-2006, 06:11 PM   #2
Burnerman
Gear oil....If you're new to the Jeep world get a repair manual and read the FAQ thread that this quote comes from..
What fluids do I use in my Jeep?
Axles - Gear oil - 80 weight for light duty and normally cooler climates - 90w120 weight for heavy duty and normally warmer climates Note: Some rear axles are equiped with factory posi - a limited slip additive must be put in with the gear oil to extend and protect the limited slip action
Engine - 10w30 for good general usage in most climates - 5w30 for those colder climates (when temps are below freezing for extended periods of time)
Transmission (standard) - 80 weight gear oil
Transmission (automatic) - Automatic Transmission Fluid (ATF) Dexron III
Transfer case - Automatic Transmission Fluid (ATF) Dexron III
89' YJ Larado 4.0L,AX15
01' Grand Cherokee 4.0L
Check my Gallery for pics.
My Rebuild Thread
Take a minute and fill out your profile, Please
Burnerman is offline   Reply With Quote
Old 12-17-2006, 07:04 PM   #3
Tom95YJ
It's Only Rock Rash......
Tom95YJ's Avatar
You need to be more clear on what you are doing so we know what to put in
I can think of a few things you could possiably want to put in like a Carrier for an open diff, A Full locker , Lunchbox locker , center pin , bearings, ring/pinnion, spacers, thrust washers, spider gears, diff fluid......... you should get my point by now
'98 TJ Built Sold
'95 YJ Built Sold
'99 XJ 3" on 31's Build Thread
Utah Jeep Crew Member #109
Tom95YJ is offline   Reply With Quote
Old 12-17-2006, 07:16 PM   #4
Skeezer
75-90W Gear Oil
I used Mobil 1 Synthetic
2006 TJ Sport
1995 YJ
2007 JK Sahara Unlimited
www.GrassRootsJeepClub.com
www.GrassRootsJeepClub.proboards80.com
Skeezer is offline   Reply With Quote
Old 12-17-2006, 08:12 PM   #5
Bob_R
newbie
Are you asking about gear oil or what type of gears?
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL TREAD LIGHTLY
Bob_R is offline   Reply With Quote
Old 12-17-2006, 09:10 PM   #6
MTGunNut
Oh geez, Im sorry though, but I was talking about gears themselves.
Old 12-17-2006, 09:17 PM   #7
bobbert350
so do u need to rebuild them i mean the gears? or do u want to no what ur gears are? or what gears you should get?? please be more specific
bobbert350 is offline   Reply With Quote
Glock Forum
