Differential Lube Change - JeepForum.com
post #1 of 8 Old 11-04-2012, 04:26 PM Thread Starter
flcracker
finally got that done today and found that the rear diff has a rubber plug in it instead of a real threaded plug?? I had no idea the rear was like this and can only assume all of them are like this??
flcracker is offline
post #2 of 8 Old 11-04-2012, 04:29 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
All '89 & newer Dana 35 axles have this plug. Previous model years have a threaded plug.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 8 Old 11-04-2012, 04:31 PM Thread Starter
flcracker
Is it something that can be replaced easily or even something to worry about?? Just seems pretty important part to be made out of rubber like that....
post #4 of 8 Old 11-04-2012, 04:33 PM
Jeepsr4me
yours is over 20 years old and the plug has worked just fine all that time. Yes it is fine.
Jeepsr4me is offline
post #5 of 8 Old 11-04-2012, 04:37 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
DORMAN Part # 090062
Max
Mean Max is offline
post #6 of 8 Old 11-04-2012, 06:53 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Try a different rear axle if you're not happy.
Luck Favours The Prepared
Anticanman is offline
post #7 of 8 Old 11-04-2012, 07:40 PM
sdotcarter
Nick, I think mines going bad right now. Ill be bugging you shortly when I go on a junk yard run.
sdotcarter is offline
post #8 of 8 Old 11-05-2012, 05:10 AM Thread Starter
flcracker
Don't have the budget for that right now.... trying to get it solid before we start doing fun stuff to it....
On the list:
new windshield frame and glass
electric fan set-up
U-joints for front driveshaft
seats are a bit rough
paint inside and out
needs a top (son drives it for DD or will be very soon)
Transmission synchros are a bit rough (it doesn't like to downshift to 4th or 3rd)
Upgrade at rear axle when it actually works (knock on wood)??
