differential help - JeepForum.com
post #1 of 7 Old 05-08-2016, 03:34 PM Thread Starter
npa4863
differential help
i have a 90 yj with a 4.2l, i just put in salvage yard 4.10 stock axles from a 95 2.5l yj because my original rear pinion was flopping around and was going to fail soon... recently i had a laps in judgment and i blew out the spider gears and fractured the carrier... im trying to get this done on the cheap and fast as its my daily driver and im borrowing my dads truck to survive.
both axles are dana 35's
so can i put my 90 carrier in my 95 axle then get like a spartan locker and toss that in and a pinion kit? should i just put regular spiders back in?
i realize now with all the money i put into axles i could have got an 8.8 or a d44 but thats no longer an option i really dont have the money for another axle plus conversion parts
90 yj 4.2 Howell'ed>4"rough country lift>Warn M8000>Smittybuilt SRC bumper>31"kumho road venture mt>
npa4863 is offline
post #2 of 7 Old 05-08-2016, 04:55 PM
bruinjeeper
i think you'd still spend less on the 8.8 or d44 IMO. What size tires you running? There must be a reason the d35 imploded on you.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
bruinjeeper is online now
post #3 of 7 Old 05-08-2016, 05:00 PM Thread Starter
npa4863
32"s... But i did clutch kick it... So not the best way to keep it healthy.
npa4863 is offline
post #4 of 7 Old 05-08-2016, 05:59 PM
Drednot
no, it won't work. The carrier break is at 3.55.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #5 of 7 Old 05-08-2016, 06:03 PM Thread Starter
npa4863
Originally Posted by Drednot View Post
Your question is confusing. If you just put in a pair of stock 1995(4.10) axles in place of your 1990(3.07) units, why do you want to put the carrier from the 90 axles into the 95?
And no, it won't work. The carrier break is at 3.55.
Just put the locker directly in the 95 axle.
Since you mention cheap and fast, you are referring to a lunchbox type locker. It replaces the spider gears and crosspin. You don't need to buy anything
Il have to replace the carrier too because i fractured the spider gear housing. I was hoping to use my old carrier to save money.
npa4863 is offline
post #6 of 7 Old 05-08-2016, 06:51 PM
cyoos
Worst case scenario: put new bearings in your old D35, swap it back into your rig until you can either get an 8.8 (highly preferable) or repair the other D35, and pull your front driveshaft to be on the safe side.
cyoos is offline
post #7 of 7 Old 05-08-2016, 06:55 PM
cyoos
Check your old axle and see what ratio gears are in it. Just because most I6's came with 3.07's doesn't mean they all did. I've come across a few cases recently with later 4.0/5 speed Jeeps that had 3.55's in them.
cyoos is offline
