Differential Experts Needed. - JeepForum.com
post #1 of 7 Old 07-21-2012, 08:56 PM Thread Starter
moonpie312
Ok, first off what I'm dealing with is a D30 front differential that I bought with 4.10 gears to put in my Jeep. I bought it with a matching rear out a 4 cyl Jeep. The rear was in great shape mechanically, its already in my Jeep, now the front, is all rusty inside... Bearings are shot.
So.
Question is, Can I replace the bearings and just make sure I put all the shims back in exactly where they come out and not have to get somebody to check it with the marking compound and with a dial indicator setup?
moonpie312 is offline
post #2 of 7 Old 07-21-2012, 09:00 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
It can be done, but it's a gamble & tricky too. It's least dangerous when done by someone with a lot of axle experience. But if you're just learning & inexperienced, you can have a severe issue & not know it until it's too late.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 7 Old 07-21-2012, 09:17 PM Thread Starter
moonpie312
Well I know the basics and how it all works, plus I've read a lot and watched videos and whatnot on it, I just don't want to buy the setup tools. What is there that could bite me in the rear if I miss something? I have the press and all the proper tools to press bearings on and off with.
post #4 of 7 Old 07-21-2012, 09:32 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Really, the biggest worry is the pinion. If there is a crush sleeve (some Dana 30s have them & some don't) just avoid being too aggressive on tightening the pinion nut.
The carrier bearings are a breeze. The bearing caps are marked by Dana for each side & orientation, so just pay attention. Also keep all the shims organized so they end up where they started.
Max
Mean Max is offline
post #5 of 7 Old 07-21-2012, 10:19 PM Thread Starter
moonpie312
Well pinion bearings are something I've had bad luck with in the past, so I would be willing to invest in an inch pound torque wrench to check the rotational resistance of the pinion like its supposed to be done. So if that's my biggest worry, I can just do that part exactly how its supposed to be, and the rest should be a breeze?
post #6 of 7 Old 07-21-2012, 10:20 PM
deathtrap
It can be done, It works best if you use the same brand bearings as what you remove (timken nsk ect.) But really the "set up tools" are well worth the dough. All you need is a cheep dial indicator and a beam type inch pound torque wrench to verify that its good. you can get this stuff at the cheep tool stores or on ebay. And these tools can be used for countless other jobs.
deathtrap is offline
post #7 of 7 Old 07-22-2012, 07:47 PM Thread Starter
moonpie312
Thanks for the tip on using the same brand bearings deathtrap. I know the setup tools would be worth it to have for later jobs considering I'm always working on something. I currently have 5 projects going at once... I'm just a cheap bastard, money is always short when your buying parts and guns.....
Paint experts needed (too long) TheBoogieman TJ Wrangler Technical Forum 7 02-16-2011 03:50 PM
NP231 and SYE Experts needed bikepharmer YJ Wrangler Technical Forum 12 10-22-2010 07:58 PM
axle/steering experts needed richchs62 YJ Wrangler Technical Forum 5 10-10-2007 09:30 AM
help plz, experts needed. MeGAMoE TJ Wrangler Technical Forum 1 03-06-2007 11:30 AM
Power steering experts needed Tri_X_Troll TJ Wrangler Technical Forum 3 10-03-2005 02:43 PM
