A different approach to the 2.5 / 4.0 swap. Have an idea. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > A different approach to the 2.5 / 4.0 swap. Have an idea.
Zone Offroad - Jeep Forum PromotionFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-24-2014, 02:12 PM   #1
JohnFM3
My sister recently received a family members 88 YJ. Partially due to the condition, mainly due to sentimental value, we have no interest in selling an getting a 4.0 version. Let alone, the frame an tub are in better shape that most non restored jeeps.
So what I understand we have. This is a 88 Jeep YJ, an if memory serves me correctly, running the Chevy 2.5L 4 cyl an fuel injection. An the power train is a BA-5 5sp with a 231 tcase an dana 30/35 which I confirmed are running 4.11 gears.
My thought is this, since the major issue of this swap is the fuel injection an the effort involved with swapping the harness, is it possible to maintain the factory harness?
So this is what I want to ask the forum. What if I perform the conversion with a 4.0L H.0. an instead us the Clifford Research (6=8) intake manifold meant to be used with a Chevy 350 throttle body (Howell injection conversion). To my knowledge, this would allow me to maintain the factory harness, an add the plug for the second injector in the TB (since they are batch fire anyways).
Yes I am aware of the changing of the motor mounts. I am not sure if the 4.0 will bolt up to the BA-5, I know that with me behind the wheel the BA-5 wont hold up. But this is my sister who for the time being wont be hard on it. Assuming the BA-5 can bolt to the 4.0L, when it does die a swap to a 92-95 5sp would be in order.
I also understand that the radiator is the same between the 2 engines, just change the hoses.
Anything else I need to think about, assuming the fuel injection thought is on track.
John
John Moore ~ Real Men Still Crawl...
97 XJ (Diablo) 4.0L H.O. w/AW4 4sp Auto Dana 30/Chry 8.75 2.5 inch Flowmaster Exhaust 4 inch Lift w/ 32inch tires & RS5000 Shocks
92 YJ (BOSS) 4.0L H.O. w/AX-15 5sp Manual, 231 TCase, Dana 30/8.8 (3.73) 2.5 inch Flowmaster R.E. 2 inch lift and 2 inch body lift for CJ clip
XJ http://www.cardomain.com/ride/2634588 YJ http://www.cardomain.com/ride/3322306
JohnFM3 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2014, 03:10 PM   #2
The_Goob
Hell on Wheels
The_Goob's Avatar
I cant vouch on the intake idea, sounds like an over-complication of things to me. As for the tranny, plan on replacing with an ax-15. I was unaware of a ba-5, I thought they all used Ba-10. it is regarded as one of the worst transmissions ever used, at least in a jeep.
The_Goob is offline   Reply With Quote Quick reply to this message
Unread 07-24-2014, 03:17 PM   #3
JohnFM3
Is it the BA-10? I will check that again. I can say its stock for a 2.5L. I do understand that its the worst of them.
Thanks
Unread 07-24-2014, 03:27 PM   #4
The_Goob
Hell on Wheels
The_Goob's Avatar
http://www.novak-adapt.com/knowledge/ba10_5.htm apparenty called BA10/5, same thing I guess
Unread 07-24-2014, 03:32 PM   #5
JohnFM3
Hmm. Thanks. I know that I will need to pull it what ever it is. I have an 92 with the AX-15 an have been very pleased with it.
Unread 07-24-2014, 09:01 PM   #6
crackedcornish
not that it matters since you plan on ripping them out anyway, but you have an AMC 2.5L and an AX-5 transmission...and no the transmission won't go behind a 4.0
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline   Reply With Quote Quick reply to this message
Unread 07-25-2014, 02:35 AM   #7
mrdeath2000
If you're going to swap in the 4.0, all you do is add wiring for injector 5 & 6. There is a writeup around with pictures.
ECU for the 4.0
AX15
Wiring for the 2 additional injectors
weld in new motor mounts
*super brief version*
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline   Reply With Quote Quick reply to this message
Unread 07-25-2014, 05:07 AM   #8
grandboost98
grandboost98's Avatar
Wasnt there a couple years that the 4.0 came TBI like the early 2.5s? I assume that would be easier to wire up
04 Grand Cherokee Overland
72 Chevy Nova-in progress
http://tiny.cc/BRASSBALLSOFFROAD
grandboost98 is offline   Reply With Quote Quick reply to this message
Unread 07-25-2014, 06:41 AM   #9
crackedcornish
ECU for the 4.0
AX15
problem is the '87-'90 2.5L is TBI not Multiport...so there's only one injector
not that I've ever seen..carbs on 4.2's and MPI on the 4.0L's
Unread 07-25-2014, 10:12 AM   #10
JohnFM3
Crackedconish: This is my thoughts as well.
To all, as CC stated, this is a TBI injected jeep. An in this case, it only has 1 injector which is why I will need to add a second injector for the Chevy TBI.
At this time, no one has said it wont work. I am really thinking I will move forward with it.
Unread 07-25-2014, 10:14 AM   #11
JohnFM3
Ok, so this means I need to change out the tranny at time of swap. Thanks.
Unread 07-25-2014, 10:36 AM   #12
Luuca
Luuca's Avatar
OP: What you propose could eventually work, but then what do you and your sister have? A "One-Off". Many members here have one-off items on their jeeps, and several have done engine and trans swaps, no there's nothing unusual there. My point is that when something goes wrong - its a YJ SOMETHING WILL GO WRONG - troubleshooting and diagnosing what is actually wrong will be a nightmare compared to buying a $800 used 4.o HO AX15 Cherokee and swapping over the engine, trans, ECU, and misc parts that will all be on the donor vehicle. If you have a problem, you are still dealing with basically either a stock cherokee drivetrain or a stock 88 Jeep chassis, frame and firewall back harness. It makes it a lot easier to keep it up and going. An added benefit is that parts are readily available in just about any city in north america - versus some cludged together aftermarket parts concoction of "mixed drink jungle juice".
I strongly advise you to either use the Jeep 4.0 HO engine and AX15 trans with factory jeep harness and ECU or go the Full Monty and start reading up on V8 swaps. Half-measures will leave you stranded and alone.
my 2
91 YJ "Alice" 2.5L, AX5, 2.5" OME 36Rs, Revolvers, 32" Yoko ATs, 4.10 D30/35 Busted Knuckles
05 LJ Rubicon "Ghost" 4" RE, 1.25" BL, 33" Atturo MT, 4.10 D44 F/R Locked
Luuca is offline   Reply With Quote Quick reply to this message
Unread 07-25-2014, 12:12 PM   #13
HaskiE
HaskiE's Avatar
my 2
this x2!!
John, it says in your sig you already have 2 4.0L's, why not this one? do the swap with harness & ax15, no need to reinvent the fuel injection system - especially because it's 'not yours'. one thing I've learned, when doing something for someone else, do it awesome or they'll be back.
Goodluck!!
#theneverendingaxe
HaskiE is offline   Reply With Quote Quick reply to this message
Unread 07-25-2014, 03:08 PM   #14
crackedcornish
and you might want to just find a 231 with a 23 spline input gear already installed to match the ax-15...the 231's behind the ax-5 have 21 spline input gears
Unread 09-15-2014, 10:46 AM   #15
JohnFM3
An so starts the build of this YJ. After looking thru the responses to this thread, an pricing out the parts we have decide to go all out an update the entire jeep to a 95 YJ 4.0L H.O with a correctly setup fuel injection.
Purchased Parts List
Complete 98 Jeep XJ 4.0L
91 Jeep AX-15 5sp tranny with internal slave
98 231 tcast (currently attached to tranny, need to confirm year other than yard marking)
95 YJ ESC
Things to purchase
Engine Side engine mount brackets
Head Pipe
Cat Converter
Muffler
Tail Pipe
Tranny Mount (mine ripped)
Engine Mounts
Engine an Cab Wiring harness
Instrument Clusters
Flywheel
Clutch
An I am sure there are other small odds an ends such as hoses.
I have already confirmed that the drive lines are a match.
What I do need to verify is that the 95 esc is correct for 92 thru 95. I am tempted to attach it to my 92 YJ an check to ensure it works.
Last weekend was spent tearing the front clip off the jeep an pulling the Engine/Tranny/Tcase as 1 whole unit. Since I am sure everyone has seen that, I am not going to post pictures on that. Next weekend as I start the removing of the frame side engine mounts an prepping for welding I will start to talk more about what I am seeing and issues I face.
Have a good week,
John
