Differences in valve covers - JeepForum.com
post #1 of 3 Old 05-18-2010, 09:10 PM Thread Starter
drespecki
1983 CJ7
Replace '91 alum. valve cover with '97 steel one?
The 1991 YJ 4.0 that I am fixiing up has a solid looking cast aluminum valve cover that has a crack in the side... Can I take one of the newer stamped steel ones from a 1997 4.0 and use that on the 1991 4.0? I went to the auto parts store and had them lay the 1991 cork gasket over the 1997 rubber/steel one and they look the same...
It only hurts while you're breathing..
drespecki is offline
post #2 of 3 Old 05-20-2010, 09:44 AM Thread Starter
drespecki
1983 CJ7
Why can't I use this on a 1991 4.0?? It says 1993 and up!
http://www.quadratec.com/products/51104_08_07.htm
post #3 of 3 Old 05-20-2010, 09:49 PM Thread Starter
drespecki
1983 CJ7
So no one has tried to replace their '91 alum. valve cover with '97 steel one?
valve covers redpony03 TJ Wrangler Technical Forum 1 04-20-2010 06:28 PM
Valve covers, use RTV or not? tealboy1 TJ Wrangler Technical Forum 8 12-25-2008 11:25 PM
4.0 valve covers cyoos Wrangler General Discussion 0 06-08-2008 06:29 PM
4.0 IL6 Valve covers? TEXASRAM YJ Wrangler Technical Forum 1 02-06-2004 08:07 AM
Valve Covers??? bigjeep39 YJ Wrangler Technical Forum 2 11-30-2001 08:10 AM
