post #1 of Old 02-24-2010, 12:15 PM Thread Starter
USMC_JeepGuy
Difference in CJ Vs YJ 4.2?
Obviously they're both carburated 4.2L 258s but is there a difference in anything that would preclude someone from putting an older CJ (1984) motor in say a 1990 YJ? I heard a rumor that the starters are different, would that mean the flywheels are different? If the tooth count is the same then shouldn't either one work? What about transmissions, will an AX15 bolt up to an '84 motor?
USMC_JeepGuy is offline
SYE...What is the difference? ALMXDUPJEEP TJ Wrangler Technical Forum 3 10-29-2009 08:43 PM
what is the difference? Canfourjeep YJ Wrangler Technical Forum 2 02-14-2008 02:08 PM
What is the difference? sdlemaster TJ Wrangler Technical Forum 6 03-07-2007 11:19 AM
Is their a difference between 98 and 06 Tjs? JoshBowers TJ Wrangler Technical Forum 6 08-03-2006 11:31 PM
You may not post new threads
You may not post replies
