difference between t and m engine code - JeepForum.com
post #1 of 2 Old 04-27-2010, 06:01 PM Thread Starter
metsman1989
I have a 1989 Wrangler and i just put a new cam in it... i'm looking for the torque specs and i have a chiltons manual, with no answer for my engine code (t) theres only (m) in the book what is the diffference?
metsman1989 is offline
post #2 of 2 Old 04-27-2010, 06:41 PM
kloppk
The 1989 Wrangler came with two different trannys behind the 4.2.
The "M" code signifies that it has the Peugeot BA/10 5 speed.
The "T" code signifies that it has the (better) Asin AX-15 5 speed tranny.
The 4.2 engine is the same regardless of the T or M code.
kloppk is offline
Engine code p1281, engine cold for too long....which temperature thermostat to use? ShadowLawz TJ Wrangler Technical Forum 11 11-25-2014 12:23 PM
Engine Code P 304, Engine code P0304 JeepinRRT TJ Wrangler Technical Forum 4 09-23-2009 10:26 AM
94 vs 98 4.0 engine difference TJnIT TJ Wrangler Technical Forum 4 04-27-2009 11:47 PM
Difference in 05-06 Engine Computer? VnutZ TJ Wrangler Technical Forum 1 11-26-2007 11:10 AM
Difference in engine hmmhoyhoy YJ Wrangler Technical Forum 6 01-22-2006 02:49 PM
