difference between plate and flat bar? - JeepForum.com
post #1 of 9 Old 10-07-2009, 10:32 PM Thread Starter
TheNewbie
What is the difference between plate and flat bar? I am puting a winch plate on my front bumper that I've been working on and when I called to get steel prices she asked if I wanted plate or flat bar.
I'm new at metal working and wondering if there is any difference as far as working with it and quality for welding.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #2 of 9 Old 10-07-2009, 10:34 PM
AVONMATT1
exactly how it sounds steel plate or flat bar
AVONMATT1 is offline
post #3 of 9 Old 10-07-2009, 10:39 PM Thread Starter
TheNewbie
to me it sounds like the same thing.
one is a 1/4" thick "plate" that is 9" wide and one is a 1/4" thick "bar" that is 9" wide
post #4 of 9 Old 10-07-2009, 11:28 PM
95greenrio
If he's giving you a piece of plate that's 9" wide it's probably a drop or he's going to cut it for you, in your case either would work so just go with whatevers cheapest plate generally comes in a 4x8 sheet.
1995 YJ Rio Grand - work in progress
95greenrio is offline
post #5 of 9 Old 10-08-2009, 04:43 AM
jay-h
Plaiteis generally hot rolled.
Bar can be either hot or cold rolled (and has 'finished' edges). Cold rolled is stronger, and better finshed, but in this application the difference in strength is probably not significant.
jay-h is offline
post #6 of 9 Old 10-08-2009, 04:54 AM
Matt_vs_YJ
Either way, 3/4" is overkill for a winch plate. 3/8" would be plenty, most plates you buy are 1/4" anyway.
Call me Matt. I have a YJ.
If you're in the Hampton Roads area of Virginia check out the Middle Peninsula Jeep Association
Matt_vs_YJ is offline
post #7 of 9 Old 10-08-2009, 07:24 AM
texas_yj
plate is in sheets (like 4x8, sometimes bigger) and bar is long thin strips (usually 20+') 3/4 is way too thick for a jeep (and heavy), thats larger than what they'ed use on a tank recovery tank. as long as you have it shapped like a C or I, 1/4" is more than strong enough, if your just going with a flat piece accross the frame rails, then 3/8 or 1/2. if you have a harbor freight in your area, they sell a universal winch plate for less than you could probly buy the raw metal, I used it and wench regularlly with it (pulled a 1 ton dually out the other day, its strong enough)
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) (Sold) 99 TJ, mustang 5.0 GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT, superlift 6" long arm, D30/44 w/ ARBs & yukons, customized warn bumpers, custom sliders, 12K winch w/ synthetic rope, custom paint
3) 2007 JKU being built now
texas_yj is offline
post #8 of 9 Old 10-08-2009, 01:21 PM Thread Starter
TheNewbie
Oh, I typo'd the 3/4" I meant to say 1/4"
I'll correct that post.
Really? I thought 6/16 would do, but wanted to go with a 1/4" just for good measure.
post #9 of 9 Old 10-08-2009, 01:23 PM Thread Starter
TheNewbie
But thanks for the info guys!
Flat skid plate? elkfan2 TJ Wrangler Technical Forum 9 02-09-2010 10:37 PM
TJ Winch Mounting Plate Flat or Raised? cvd TJ Wrangler Technical Forum 38 06-19-2009 05:55 AM
Flat TC skid plate fivedive69 TJ Wrangler Technical Forum 15 07-29-2008 09:37 AM
Go-Fer-It Offroad Flat Skid Plate Lostj TJ Wrangler Technical Forum 10 12-05-2007 12:31 PM
Flat towing difference skip97 TJ Wrangler Technical Forum 6 12-23-2006 11:27 AM
