Difference between H.O. and Non H.O. 4.0L? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Difference between H.O. and Non H.O. 4.0L?
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 10-26-2008, 08:03 PM   #1
90yjkrawler
I know that people have told me not to get a non H.O. 4.0L that was older than 1991. I just don't know why. So I bought a 91 4.0L but I've come across an 89 I think it is. I need to know what the difference is before I get it. I'm thinking of using it as a backup!
Until They All Come Home!
90yjkrawler is offline   Reply With Quote
Unread 10-26-2008, 08:07 PM   #2
Brandon_YJ
1987 YJ Wrangler
I believe, and don't quote me on this, that the major difference is that the head on the HO flows much MUCH better.
I mean, I know the head is all that and a bag of chips on an HO as compared to a non-HO, but I'm not sure what other changes were made to the engine.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using Elinks in a (text only) terminal. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused click here to see how I view the forum.
Brandon_YJ is offline   Reply With Quote
Unread 10-26-2008, 08:08 PM   #3
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Read the Renix info in the XJ FAQ section. It is a completely different head, fuel setup.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Unread 10-26-2008, 08:11 PM   #4
Cross
I did not look for anything older than a 91 due to the fuel injection. There was no way I was going to deal with having a carb. Not to mention off roading the fuel injection performs a lot better.
Cross is offline   Reply With Quote
Unread 10-26-2008, 08:40 PM   #5
sprowley
craptastic fuel injection, if I'm remembering correctly. 90 and back have a ****ty Ren/ix TBI system and 91 and forward have a good EFI setup.
sprowley is offline   Reply With Quote
Unread 10-26-2008, 08:47 PM   #6
sprowley
4.0's came in XJ's since 86 I believe though, so there are a good number of spare non-HO 4.0's out there, even though they didn't start life in a Wrangler.
Unread 10-27-2008, 05:24 AM   #7
wendell
1987 YJ Wrangler
In 91 they improved the head, cam and efi set up and called it HO. Before 91 they used the franch efi system and the head was about as good as the 258. However, the non HO 4.0 wasn't a sloutch at 77 hp and good torque numbers, but it had the weird tb that was hard to upgrade or do anything with except port it.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline   Reply With Quote
Unread 10-27-2008, 08:53 AM   #8
Whitey2001
Junior Member
Whitey2001's Avatar
I have a '90 Non-HO that I am stroking to 4.7L. It does have a weird TB that I bored out to 60mm and had to JB Weld the wall because it was so thin. It is a P.I.T.A. to find performance parts for the Non-HO. If you can find parts, they are 2-3 times more expensive than for the HO engines. I chose the Renix engine partly because of price, but also for the knock sensor. I plan on running a compression ratio of 10.2:1 so that I can use e85. In case I can't find e85, I wanted my computer to have the ability to adjust timing to reduce knocking while on regular gas. I did have to port the head, but with everything I am doing to it, I expect to get 230-250 HP out of it.
'04 Rubicon
Whitey2001 is offline   Reply With Quote
Unread 10-27-2008, 09:52 AM   #9
Mobile_Homie
Blood, Guts & Rocks
Mobile_Homie's Avatar
Get a 91 or later 4.0 HO and don't look back just my $.02
Happy Wheelin'
Mark
Smoke em if you got em!
Click here
Mobile_Homie is offline   Reply With Quote
Unread 11-04-2008, 03:01 PM   #10
90yjkrawler
Whats a knock senser? Is that something that adjusts the fuel pres or air fuel ratio? The HO 4.0L doesn't have this?
Unread 11-04-2008, 06:32 PM   #11
Mean Max
Don't poke the bear
Mean Max's Avatar
A knock sensor is a block mounted sensor that detects pre-ignition knocking. It helps remedy the knocking by retarding the ignition.
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 11-04-2008, 11:11 PM   #12
dukegnarley
i have a renix 4.0 in my yj. I also cry myself to sleep at night.
Unlimited Length YJ "Sasquatch"
Build Thread
Renix 4.0
AW4 swap with awshifter = DONE
custom console
flatdash
dukegnarley is offline   Reply With Quote
Unread 11-04-2008, 11:23 PM   #13
ech0sh4y
2005 WK
how can you tell if you have a Ho or not?
~ Brian
'08 Jeep WK - Overland - Ya... it's got a hemi!
'96 Bronco 5.8 - Work in progress.
'98 ZJ 5.9
ech0sh4y is offline   Reply With Quote
Unread 11-05-2008, 02:01 AM   #14
dukegnarley
wranglers didn't come with the renix. the only way you'd have one is if someone swapped one in. the renix engines have the throttle connect on the back side of the throttle body while the ho has it connect on the front side of the throttle body.
Build Thread
Renix 4.0
custom console
flatdash
Unread 11-06-2008, 09:48 AM   #15
ech0sh4y
2005 WK
so all post '90 4.0L, if not swapped out previous, are H.O. motors?
~ Brian
'98 ZJ 5.9
