Difference between cj/yj headers? - JeepForum.com
post #1 of 6 Old 09-21-2013, 09:44 AM Thread Starter
Maine1994ZJ
The search function proved useless for my question... Again.
I also found nothing in the FAQs
Is there a difference between a header for a CJ w/258 & standard trans and a header for a YJ w/258 & standard trans?
I prefer to shop locally as much as possible and would rather use my normal local suppliers if at all possible.
Of the 2 suppliers I use most, neither can produce a YJ header for my application, but both can find a header for a similarly equipped CJ.
Will the CJ header work on my wife's YJ, or are they 2 different critters?
I'm sure someone here will have some insight for me.
Thanks in advance!!!
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #2 of 6 Old 09-21-2013, 11:47 AM
Reno72
There was a thread about this, I don't remember all of it, but there was a difference between the headers. Here is one for an "87-91". It's not cheap, but I have it on my 4.0 and it made a noticeable difference.
http://www.quadratec.com/products/17601_03_07.htm
BTW When my YJ had trouble passing smog, the test facility said my Borla header had the 02 sensor reading only 3 cylinders. I called up Borla and they said the new ones fit after the collector and read all 6. They sent a new one out at N/C.
Reno72 is offline
post #3 of 6 Old 09-21-2013, 11:55 AM
roadyrob
1987 YJ Wrangler
a cj is passenger side front axle, they yj is drivers side so the header is made different to clear.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #4 of 6 Old 09-21-2013, 01:12 PM
c5wagner
x2
1989 Base YJ TBI 350, 4l60, Np231 SYE/6 pin planetary/Wide chain, D30 ARB, 8.8 ARB 4.56
c5wagner is offline
post #5 of 6 Old 09-21-2013, 10:55 PM Thread Starter
Maine1994ZJ
Thanks for the clarification guys!!
The search is on!
post #6 of 6 Old 09-22-2013, 06:55 AM
superj
Also, some cj headers have deeper mounting flange bolt holes. Like over an inch deep.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
