Diff hot after spider replacement - JeepForum.com
post #1 of 3 Old 04-12-2007, 07:49 AM Thread Starter
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Replaced chewed up spiders, now have a gurgle/vibe noise coming from the dif, (only when carried spinning)and It's hot after a 20-30 min drive.
I broke 4 teeth off the left spider/axle gear.
I pulled used spiders and left spider/axle gear froma 35 at the boneyard. My right spider/axle gear was ok so I left it in. I used the new to me center spiders because they were in better shape than my old ones. All works fine, but it is noisy and is getting hot on the diff cover. Not hot enough so you can't touch it, but warmer than I think it should be.
So last night took it all apart again to ensure I had the carrier in straight and flush. It's good. But had a mark on the diff cover where the ring gear seems to be making contact, not much but the mark is definately there. Also had a good amount of the "glitter" flakes come out with the fluid.
So I cleaned it all out again and put it all back together. Same thing.... Any ideas? I'm using black RTV form a gasket with seems soupier than the other RTV gasket stuff. I let it set up for about an hour before I put the cover on, but it's still soupy. Is the clearance that tight? My carrier is bolted up as snug as it gets.
- Ernie
Richmond88yj is offline
post #2 of 3 Old 04-12-2007, 09:35 AM
Jeepwheeler2
If the ring gear is contacting the diff cover then either the cover is dented, or the carrier is not installed properly.
'96 XJ 4.0 AW4, 3" Homebrew lift, homebuilt tree felling bumper, warn x-case skid, roof mounted spare and hi-lift, lots of custom bent sheetmetal.
Jeepwheeler2 is offline
post #3 of 3 Old 04-12-2007, 09:52 AM Thread Starter
Richmond88yj
Eat, Sleep, Jeep
Thanks, yeah, after reading through Randy's Ring and Pinion faq's it looks like it's bearings, not the ring gear, must have been an old scratch.
I guess I've got some dirt/crap on them when I did the spiders.
Time to pull it all out again tonight and clean it good, then try again...
- Ernie
Driving with no spider gears in front diff? mbuna TJ Wrangler Technical Forum 12 05-28-2012 03:55 PM
DANA44 can't remove diff ls spider gears shaft pin imoafa TJ Wrangler Technical Forum 10 09-28-2009 12:59 PM
broken spider gears!! ideas for replacement saharajeepman YJ Wrangler Technical Forum 11 04-26-2008 01:06 PM
Bad rear diff spider gears vbguru12000 TJ Wrangler Technical Forum 13 11-03-2007 07:27 PM
Spider gear replacement OlllllllO Jeep1 YJ Wrangler Technical Forum 6 11-23-2005 08:55 PM
