Died while going down the road... - Page 2 - JeepForum.com
post #16 of 23 Old 11-03-2010, 08:22 AM Thread Starter
jhumphrey
Thanks Mark. Where are the two fuses located? Also, I was told that within the last year they had replaced the ignition switch, alternator, and starter. With that being said, obviously, whoever they had do the work was shoddy. I say that because if it was replaced in the last year or two, the starter is bad (according to AZ), which means they prob used a used part to replace it with and charged them for a "new" one. I do know that the alternator is a refurb, it clearly says it on the alternator. I think the battery could be the culprit as well, do to the fact that it wouldn't spark the ends of the jumper cables when I did. But, if that were the case, would there still be enough juice to light up the dashlights, headlights, and taillights?
I dont have a garage and its raining today, so I wont be able to really mess with it, unless it stops soon and I can get to it after work.
jhumphrey is offline
post #17 of 23 Old 11-08-2010, 05:02 PM
360yj1989
In my experience with my own jeep i've found occasionally you will have more than one small problem that together creates a big problem. I had a similar issue with mine. it would crank but out of nowhere it would sputter and die. Messed with it for months before figuring out that it was a clogged fuel filter. I had already changed the filter but later discovered a second one that you could only get to with the gas tank dropped.
360yj1989 is offline
post #18 of 23 Old 11-08-2010, 06:22 PM
Brumble83
It sounds like you got moisture in your distributor cap when degreasing your engine. That's why it spit, sputtered and bogged out. Remove your cap and dry it out.
But, I don't know why it won't turnover.
Brumble83 is offline
post #19 of 23 Old 11-09-2010, 05:22 AM Thread Starter
jhumphrey
Since it could have been anything under the sun, I took it to a local jeep mechanic for an inspection / repair. I simply don't know enough about what all it could be to figure it out.
Since I have technically not purchased it, the owner is footing the bill. However, I did find a 98 TJ for sale at a good price as well. I know that one has been really taken care of and am leaning toward getting it....
post #20 of 23 Old 11-09-2010, 02:48 PM
timatoe
timatoe's Avatar
#1 No crank sensor on a 4.2
#2 Starter very well could be bad, because it dies frequently and is seen way more than typical use.
#3 Dies, because of a) clogged venturi tubes in crap carter carb or b) Ignition Control Module is going out.
That's my
timatoe is online now
post #21 of 23 Old 11-09-2010, 08:03 PM
srwilson8074
If the truck ran fine up until you washed it, I would check for moisture under the cap, electrical ignition drying spray would help.
S.R. Wilson Sr
srwilson8074 is offline
post #22 of 23 Old 11-09-2010, 08:04 PM
srwilson8074
If the truck ran fine up until you washed it, I would check for moisture under the cap, electrical ignition drying spray would help. The starter and the Alternator could also contibute to this problem.
S.R. Wilson Sr
post #23 of 23 Old 11-10-2010, 08:06 AM Thread Starter
jhumphrey
I got a call from the mechanic today. Apparently, there was some exposed wiring that touched some fuses, causing overheating, thus melting the fuses. He's going to have to re-wire to fix it. Im going to talk with him today more in depth about what he's rewiring....
ignition , stall , starter
Jeep died running 45mph down road Jprevette YJ Wrangler Technical Forum 11 12-20-2009 09:04 PM
Advice on increasing on-road ride quality without sacrificing off road Lord_Xcalibur Wrangler General Discussion 15 12-15-2008 08:41 PM
Rough road hop on smooth road xxcyted TJ Wrangler Technical Forum 5 07-27-2008 12:14 AM
jeep died going down road!!! jptaylor2 TJ Wrangler Technical Forum 10 10-01-2007 12:18 PM
Best shocks for on road and off road edelbrock? odie YJ Wrangler Technical Forum 2 12-25-2001 06:31 PM
