Died on me today, any ideas? - JeepForum.com
post #1 of 31 Old 11-25-2013, 05:32 PM Thread Starter
cstealy
Hey guys, I just bought a 95 YJ yesterday and after getting used to stick again took it to the lot down the road from my house that is used for dirtbikes to try taking it offroad. Everything was fine on the terrain and hills and this puddle there about 2" deep. I drove through it several times and kept going, on the last one though it stalled and refused to start again.
The air filter seemed dry, as did the throttle body after I took the intake off. The distributor was a little dirty inside, but no water was in there. We shot some engine starter in the intake but that didn't help. None of the fuses are blown. I left it locked up in the lot with a note incase it needs towed to a shop but figured I would hop on here and ask if anyone had other ideas.
I'm going to go back a little later and try and start it and again tomorrow before I actually get it towed- see if something just needs time to dry.
Thanks for any help
cstealy is offline
post #2 of 31 Old 11-25-2013, 08:44 PM
jokerchief462
No spark something is wet in the ignition circuit. Could have water in a connection like COS located 10 o'clock on the bell housing. Tons of connectors on the engine and the coil. Dizzy cap could have cracked from cold water. Need to tow it home and start looking.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 31 Old 11-25-2013, 09:30 PM
brzehentmaier
brzehentmaier's Avatar
[quoteNeed to tow it home and start looking.][/quote]
x 2^^^ .At home you will have the time to really let it dry out and track down the problem.
Bernie
1995 Rio Grande
31 x 10.5 x 15 Tires
1.5 Body Lift - Skyjacker Hydros
2.5 - Auto - Crager "D" Slots
A Work In Progress
2004 Liberty Columbia Pkg.
A new begining
brzehentmaier is offline
post #4 of 31 Old 11-26-2013, 06:52 PM Thread Starter
cstealy
so i took it to a shop today thinking it was electrical and it was. Would up frying the computer with water and mud.
In addition to that the mechanic said my front end ball joints need replaced as well as my O2 sensor.
My question to all of you who have had jeeps for a while and worked on them, how easy is it to replace these parts? I'm sure buying online will be cheaper than shop prices, but what kind of equipment will I need and are they decently easy to replace or should I just have the shop do it? Or what is the price ceiling I should put on it to have them repair vs. doing it myself. I can find upper and lower ball joints for 17-25$ each and an o2 sensor for about the same price.
thanks in advance for any help
cstealy is offline
post #5 of 31 Old 11-26-2013, 07:01 PM
superj
They immediately say ball joints as soon as a yj pulls into a shop. Was it Firestone?
I have never had to change ball joints so I cannot help on the tools or anything for you
The 02 sensor is super easy
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #6 of 31 Old 11-26-2013, 07:12 PM Thread Starter
cstealy
K no it was not firestone, it was Silverdale Autoworks, they seem fairly legit, but I know how autoshops work. From a buddy of mine with a cherokee he says have they do the joints because sometimes they need special presses. I am not too car savvy but with a Haynes manual I'm pretty decent.
cstealy is offline
post #7 of 31 Old 11-26-2013, 10:18 PM
95yj0645
If you aren't too car savvy then let a shop do ball joints, because after the first set you do you wont want to ever pick up a wrench again lol unless you know the tricks.
If you think they are jackin' you around get a second opinion. Ball joints pay good shop labor and are relatively inexpensive parts so that's why a shop will push that sale. Because Im sure you just paid $400+ for that computer...
95yj0645 is offline
post #8 of 31 Old 11-27-2013, 07:55 PM
Que89YJ
You didn't fry the computer. You need to clean all the connectors including the computers and put dielectric grease in all the connectors. Look up how to check your fault codes by cycling the key and see what codes you have.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #9 of 31 Old 11-27-2013, 08:12 PM
Raindem
Second that. I have a hard time believing 2 inches of water is going to do all that damage.
If it ain't broke... break it.
Raindem is offline
post #10 of 31 Old 11-27-2013, 09:12 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
X3 I splashed through this a few times before I got high centered on a submerged rock. No issues with my jeep other then no drain plugs and getting 4" of muddy water on the inside
I've also done some stream crossings in the Yj where water was upto the parking lights on some local ohv trails. Which submerged the ICM with no issues.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #11 of 31 Old 12-01-2013, 08:21 PM Thread Starter
cstealy
Thank you all for the input. Without a 2nd car I wound up just having a company rebuild the computer, whether or not it was broken or my fault I need it running, then I'm taking it to a local 4x4/jeep store to ask about the balljoints and see how much they want to fix them.
So a couple things I'm thinking about doing to it other than o2 sensor and ball joints, are add a winch and air compressor. eventually when I need new tires I'd like to throw a couple inches of suspension lift and up the tires to 33 or 35". is there some sort of splash guard to keep water from spraying up under the hood? Or should I just build a box around the control module and air intake?
cstealy is offline
post #12 of 31 Old 12-01-2013, 09:08 PM
Que89YJ
You still need to dielectric the connectors. It is a must for any jeep that you plan on putting into water.
Fault codes:
No Start:
Que89YJ is offline
post #13 of 31 Old 12-01-2013, 09:49 PM
SeanB95YJ
you shouldn't have to worry about any spray/splash under the hood area (other than possible issues with the distributor or air intake)
From my understanding (Que, please correct me if I got wrong info) the YJ (and possibly all Jeep?) computers are "potted", meaning that once all the circutry is put together, it's basically dipped in some sort of rubber/plastic type resin to completely encase the electronics.... they can basically run just fine fully submerged. your only weak link being the connections as Que said - Dielectric grease goes a long way to protect here.
Good luck
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #14 of 31 Old 12-01-2013, 11:48 PM Thread Starter
cstealy
Awesome thank you guys, I'll make sure it gets dialectric grease.
cstealy is offline
post #15 of 31 Old 12-02-2013, 06:24 AM
WDNewman
No way you needed a computer. Unless the vehicle was going wobbly all over the road you probably didn't need ball joints either. You need to educate yourself on both the Jeep and mechanical repairs before you even start to think about lifts, tire sizes, winches and compressors.. This forum is a good start.
WDNewman is offline
