Quantcast Died on highway this morning - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Died on highway this morning
Old 04-19-2008, 12:17 PM   #1
blue1989yj
My 89 died on the way top work this morning. One minute I was cruising at about 65, then the engine hesitated, lost power, and quit. It would not restart. I recently nuttered and set timing between 8-9 degrees before. It had never run as smooth as this. It was towed back to the house, where it will sit until I can come up with a fix. Any thoughts? Thanks.
Just did new oil, filter, plugs, as well.
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline   Reply With Quote
Old 04-19-2008, 12:52 PM   #2
93jeepREDSOX
Was there a strong smell of gas or does it not even crank. Could be fuel pump.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline   Reply With Quote
Old 04-19-2008, 01:10 PM   #3
blue1989yj
It cranks, but will not turn over. I don't think it is the pump but I will look for sure. Any tips? Or just listen for it to kick on when the key is turned?
No strong gas odor, but then again I wasn't paying attention to it at the time. I was just angry and becoming late.
Old 04-19-2008, 01:33 PM   #4
93jeepREDSOX
Well when mine went it smelled like gas really strong and there was a puddle of gas under the tank, could maybe just be the fuel filter. Does is sound like it is not getting gas?
Old 04-19-2008, 01:36 PM   #5
ctm
you have to do it step by step...
is there fuel
- do you have a spray of fuel in the carb
- if not, disconnect near the fuel filter and put end of line in a plastic cup - crank engine
- does fuel fill the cup, if not then start looking at the fuel pump
is there spark, remove one plug, touch it to the block w/ insulated pliers - have a friend crank.
- either there's spark or not.
- if not, does coil + have 6-12V with key in run
- if not look at resistor wire or ig switch.
- if so then start looking at ign module.
etc etc you need to track it down
ctm is offline   Reply With Quote
Old 04-19-2008, 01:46 PM   #6
blue1989yj
I will look at it and let you know what I find. Thank you all for the help. I won't get the chance to do anything until tomorrow. I won't get home until about 9 tonight and the light will be gone. I will post my findings.
Old 04-20-2008, 02:50 AM   #7
timatoe
Jello Puddin'
timatoe's Avatar
Unless you've swapped it out with an electric pump you won't hear it because it's a mechanical pump. I'm going with the Ignition Control Module.
timatoe is offline   Reply With Quote
Old 04-20-2008, 05:27 AM   #8
chadzic
Another idea. I had a similar problem with my TJ. It turned out to be the timing sensor (not sure what exactly it is called) basically just a little magnet that senses the flywheel posistion. Not sure if older jeeps used them too. Too fix it i just cleaned it off, unplugged it and plugged it back in.
chadzic is offline   Reply With Quote
Old 04-20-2008, 07:19 AM   #9
BillsFan
If it's what I'm thinking of it goes by many names I know it as the CPS or Camshaft Position Sensor.
My 02 F350 has one, does an 89 YJ?
2005 Grand Cherokee 5.7 V8 HEMI Blue
1986 CJ7 Project Jeep 4.2 I6 Camo For Sale
2002 F350 7.3 PowerStroke V8 Arizona Beige
BillsFan is offline   Reply With Quote
Old 04-20-2008, 08:06 AM   #10
ctm
no CPS......
Old 04-20-2008, 08:36 AM   #11
BillsFan
Originally Posted by ctm View Post
no CPS......
That solves that.
Do the newer Jeeps have them?
Old 04-20-2008, 09:05 AM   #12
90jeepman1
replace the modgel and the coil
90jeepman1 is offline   Reply With Quote
Old 07-18-2008, 03:38 PM   #13
Spankyzbt13
Resurrection Of Thread
Hi,
Using the search feature, I found this thread. THE EXACT SAME THING happened to me in my '89 4cyl. 5 days ago.
I have not begun to tear into the problem.
Was there ever a resolution from this?
Please let me know
Thanks
Spankyzbt13 is offline   Reply With Quote
Old 07-18-2008, 04:32 PM   #14
Chris
I do stuff
Chris's Avatar
Pull the gas cap off, push jeep out of garage, push new jeep in and replace gas cap, good as new
Chris is offline   Reply With Quote
Old 07-18-2008, 10:34 PM   #15
joho
just went through this exact same thing I replaced several things so not sure which one it was Ignition mod
coil
wires
plugs
distributor pick up
I think it may be Ignition mod because I nutter it and crimped and taped the wires and I think Water shorted out the module (come to find out after a 500 bill from a mechanic) and did not know where to start because most everything was new .but turned out to have shorted the coil and module
Hope this helps it was a pain in the ***
Also before this it did it too and I dropped the tank to find a peice of old hose in there stopping the fuel so you may want to drop and clean your tank if you never had.
joho is offline   Reply With Quote
Glock Forum
