Did your cracked exhaust manifold look like this? - JeepForum.com
post #1 of 15 Old 03-30-2010, 05:36 AM Thread Starter
EABiker
My 4 banger was sounding a bit rough, but running fine. I figured the manifold gasket was blown; it was, but so was the manifold!. I've read that Jeep mamnifolds would crack from trail damage issues, but this is clearly not the case here. It looks to me that this thing has been hot, very hot, and has actually began to melt! It could also have been splashed with water when it was hot; that could explain the odd cracking in the center, Or, perhaps that country of origin stamped into it had something to do with it.......
Anyway, I have been wrenching on vehicles for nearly 30 years, and never saw a manifold like this!
NAPA did have one in stock, so the story did have a happy ending!
EABiker is offline
post #2 of 15 Old 03-30-2010, 05:41 AM
Louie4
Never seen one like that. The crack on mine is where the pipes meet above the flange, as most 4.0's are. I've even replaced mine once. That looks nasty, hope the new one is a bit more durable.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 15 Old 03-30-2010, 06:15 AM
Que89YJ
You were running hot to cause the heat generated to do that kind of damage!
Que89YJ is offline
post #4 of 15 Old 03-30-2010, 07:06 AM
Burnerman
Burnerman's Avatar
Was/is the EGR hooked up on that engine? It's weird that it heated so bad in just that area yet the front and rear runners don't look that bad. It is probably a thin cheap cast in the center chamber that overheated. If the EGR is diconnected it will cause hotter EGT's.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #5 of 15 Old 03-30-2010, 07:36 AM Thread Starter
EABiker
Everything is hooked up, and I actually just passed emissions testing! Unfortunately, the new one I got came out of the same casting mold as that one did. I was wondering of the "factory" manifolds were also made in China! It would be hard to tell though with the heat shield in place.
EABiker is offline
post #6 of 15 Old 03-30-2010, 08:10 AM
Burnerman
Burnerman's Avatar
No factory Chinese manifolds. All made in USA.
96 ZJ.
post #7 of 15 Old 03-30-2010, 09:35 AM
YJdad
Actually - it looks like the heat shield has been removed? or that it never had one. Those cracks would be right under it.
94' YJ Stock 2.5L -
/ BFG 30x9.5x15 / Herculiner / Stereo console - Currently parked for overhaul
98' ZJ GCL - Stock V8
75% of the world is covered by water, the rest is covered by Jeep!
YJdad is offline
post #8 of 15 Old 03-30-2010, 09:52 AM Thread Starter
EABiker
The heat shield was in place on the engine; It fell apart on the way off of the Jeep.
EABiker is offline
post #9 of 15 Old 03-30-2010, 10:13 AM
leadsled01
I think that cracking was caused by cold water splashing onto the hot manifold.
leadsled01 is offline
post #10 of 15 Old 03-30-2010, 11:40 AM
sebastian22
just curious, how are your motor mounts? there may have been too much vibration in there due to bad mounts that caused the cracks.
95 Black YJ
sebastian22 is offline
post #11 of 15 Old 03-30-2010, 02:00 PM Thread Starter
EABiker
Actually, I did replace the mount, which was bad, while doing the manifold job!
EABiker is offline
post #12 of 15 Old 03-30-2010, 02:05 PM
sebastian22
my manifold had 2 cracks in the same spots as yours, although not as bad, they were more hairline, those look much deeper.
anyway, i always suspected that it was because of extra vibes caused by disintegrated motor mounts.
95 Black YJ
post #13 of 15 Old 03-30-2010, 04:36 PM
Billyjoebob007
Replace it with this :
Jeep Exhaust Manifold - iNeedParts.com
Whoops, my bad, yers is a 2.5.
Billyjoebob007 is offline
post #14 of 15 Old 06-04-2010, 04:07 PM
ditchdog
1983 CJ7
My buddy just showed me his manifold off a 1.5L Iron Duke... looks almost the same plus stress cracks all over. Must be from heat, but his just passed CA smog??? Anyone know of a place to find a new/used exhaust manifold for an '80 1.5L Pontiac Iron Duke?
'83 CJ7, 258, Howell TBI, 3" susp + 1" body lift, 33" MT/R's.
Build thread:
ditchdog is offline
post #15 of 15 Old 06-04-2010, 05:51 PM
clush
That is CRAZY. I think the cause is just cheap metal from China, maybe with some help from a hot engine and water splashing on it over multiple offroading trips. I used to mess around with drag cars before I started playin with jeeps and those cars mostly had headers - but they get hot as heck and I have seen some manifolds on those cars too. but never saw anything like that. I can't help but thing something was wrong with the metal or how they casted it.
clush is offline
Cracked Exhaust Manifold???? 4LiterFury2010 TJ Wrangler Technical Forum 0 02-08-2010 08:31 PM
My exhaust manifold is cracked czjeeper YJ Wrangler Technical Forum 15 05-07-2009 10:21 AM
Exhaust Manifold cracked Jeep25 TJ Wrangler Technical Forum 32 02-12-2009 09:19 PM
2.5 Exhaust manifold Cracked mtgmike TJ Wrangler Technical Forum 2 02-09-2009 11:00 AM
Cracked Exhaust Manifold Jstin120 TJ Wrangler Technical Forum 17 01-27-2008 06:25 AM
