Dick Moroso oil pan? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Dick Moroso oil pan?
Swag Off Road BIG-HIT TJ-YJ Rear BumperAll Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!
Unread 01-19-2015, 05:50 PM   #1
Jeepyj311
Is anyone running the Dick Moroso oil pan? It holds 1.25 additional quarts of oil and has a trap at the bottom to make sure there is always oil to pull from when the vehicle is at angles. Sometimes I get hung up at pretty sever angles and I can watch my oil pressure drop bc of it and was thinking of making the purchase. What do yall think? Right now I do run a bigger wix oil filter on my jeep and usually put in one extra quart before the trail ride but I think this would help me the most on those angles.
Jeepyj311 is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 06:41 PM   #2
Norcal_chris
Norcal_chris's Avatar
It couldn't hurt. Except it hanging further down. Fwiw my jeep is on its side all the time and I've noticed no I'll effects. I would be more apt to install an accumulator instead. Depends on the sump height of that pan and how much more it is going to hang down or be more vulnerable that the stock one already is
2.5/doubler,D60/14bff,108.5WB,H1s,39 Red label Krawlers ,17in beadlocks, 3link front w/ 14in Kings/4 link rear w/ 14in kings
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 07:34 PM   #3
jsawduste
2006 YJ Wrangler
Without extending the pickup your not gaining much.
jsawduste is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 11:05 PM   #4
Luuca
Luuca's Avatar
The Moroso hi performance oil pan on the Quadratec site does not add any additional depth. That means the stock pickup will work just fine. Here's the Link.
Click Free:
Originally Posted by Quadratec Site Moroso Hi Performance Oil Pan
The two kickouts allow 1.25 additional quarts of oil capacity to reduce oil temperature. The three hinged trap door baffles around the pickup screen open and close to limit the movement of oil on steep trails and quick launches and stops. The removable anti slosh top plate provides additional oil containment to reduce oil pump starvation. Includes a drain plug with rare earth magnet at the factory location and the original depth is maintained to allow fitment for aftermarket skid plates and to maximize ground clearance. Works with your existing oil pump and pickup tube and installs using existing fasteners and a standard OE gasket (sold separately). Hand crafted from heavy 16 gauge steel with a yellow zinc dichromate finish to resist corrosion. Add our Hi Volume Oil Pump assembly with pickup tube and screen to make the job complete.
Sounds like a good idea if I had an addtional $540 to throw at the heep. http://www.quadratec.com/products/51009_1012.htm
91 YJ "Alice" 2.5L, AX5, 2.5" OME 36Rs, Revolvers, 32" Yoko ATs, 4.10 D30/35 Busted Knuckles
05 LJ Rubicon "Ghost" 4" RE, 1.25" BL, 33" Atturo MT, 4.10 D44 F/R Locked
Luuca is online now   Reply With Quote Quick reply to this message
Unread 01-19-2015, 11:18 PM   #5
Anticanman
The Thunder Chunky
Anticanman's Avatar
I can't justify $400 thrown at the 4.0.
Luck Favours The Prepared
Originally Posted by rambo3489 View Post
Listen to what the canman says. You don't have to take it all word for word. But at least listen to the man. He knows his ****. Its a no BS straight to the point realistic approach to things. You may not like it. But someday you might have an Anticanman moment. Like you just had. I know I have. Hell I had 2 last week.
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 01-20-2015, 01:05 PM   #6
Luuca
Luuca's Avatar
Maybe on a full tilt stroker build. But if you're going to go through that, I'd rather have a V8
Posted via my pretentious iPhone.
Unread 01-20-2015, 01:22 PM   #7
jsawduste
2006 YJ Wrangler
That 400 would be approx. 5 % of what I get to build a stroker.
Cheap insurance.
Unread 01-20-2015, 01:42 PM   #8
Luuca
Luuca's Avatar
That 400 would be approx. 5 % of what I get to build a stroker. Cheap insurance.
Who can afford you? Lol. Just kidding. For me, blowing up my 4.0 from oil starvation on extreme angles is the least of my worries. But like I said, given a lottery win....
Unread 01-20-2015, 03:01 PM   #9
jsawduste
2006 YJ Wrangler
A stroker doesn't have to cost that much but if you want the best parts they add up quickly.
Unread 01-20-2015, 04:41 PM   #10
Luuca
Luuca's Avatar
I'm on a budget so I'm getting the Rough Country stroker kit.
Unread 01-20-2015, 04:56 PM   #11
AmmitOsiris
Does it come with superglued endcaps?
AmmitOsiris is offline   Reply With Quote Quick reply to this message
Unread 01-20-2015, 05:18 PM   #12
Luuca
Luuca's Avatar
No, but I hear the only issue is the crank sags after 500 miles.
Unread 01-20-2015, 05:32 PM   #13
AmmitOsiris
Hmm good deal, wonder if it swaps out connecting rods.
