Diamond Plate - JeepForum.com
post #1 of 2 Old 10-21-2002, 11:37 AM Thread Starter
90maineYJ
Diamond Plate
I am looking for a seller/fabricator that can provide diamond plate corners that wrap around and continue forward up the entire side of the body. I would also settle for ones that transitioned into rocker panels and stoped. Any ideas?
90maineYJ is offline
post #2 of 2 Old 10-21-2002, 12:09 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Is there a specific reason why you want the diamond plate? Is it to cover damage? Is it for looks? Is it for protection?
The reason I ask is because the diamond plating doesn't do much for your vehicle as far as protection goes. Avalanche Engineering has some corner guards that are designed to take a sledgehammer hit and not show the damage .. but they are not diamond plate .. they are smoothies for use on the big-rocks.
Damage covering is worse than fixing it right. There would endup being places for the dirt, water and such to work their way in, and cause some ugly amounts of rust and further damage to the point that you would end up needing to replace the tub with something from JP OffRoad in Spokane (or something similar .. fiberglass, aluminum, kevlar, etc) ..
Hope this helps a bit ..
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
diamond plate FromHereDown TJ Wrangler Technical Forum 3 06-28-2011 09:54 AM
Diamond Plate KJoop98 YJ Wrangler Technical Forum 5 12-20-2008 09:28 AM
diamond plate 1992JeepYJ YJ Wrangler Technical Forum 2 09-11-2006 09:08 PM
Diamond plate pix anyone? dhdallas YJ Wrangler Technical Forum 2 04-13-2005 12:36 PM
Diamond Plate Alien YJ Wrangler Technical Forum 9 09-05-2003 10:29 AM
