Dial Clock - JeepForum.com
post #1 of 4 Old 03-28-2002, 02:02 PM Thread Starter
rodgersmc
Dial Clock
Of all things to ask a question about, I'm embarrased by this one. I should be asking about an upcoming regear/axle swap/soa, but no, I'm asking about the dang clock.
Be that as it may, my clock doesn't work. Never has (since I bought it 1500 miles ago or so). Anything I can do? Does the clock just have a cheap AA clock motor on the back, or is it connected to the main battery? If its connected to the battery I can't think of a reason it wouldn't be running since my charge is fine.
When I say it doesn't work, I mean nothing at all, Jeep on or off. No movement of second hand on up. Its a small thing, but I'd like it to work.
89 YJ 4.2L
3" body lift
2" shackle lift
32" tires on 15X10's
winch
soon to be JKB2 mod
rodgersmc is offline
post #2 of 4 Old 03-28-2002, 08:08 PM
4wheeler4CJ
4wheeler4CJ's Avatar
That's a chronic problem for Jeepers, is having a Dial Clock that actually works. Fortunately there is a guy in CA at <a href="http://www.autoclock.com" target="_blank">www.autoclock.com</a> that will rebuild any auto clock with a quartz movement! <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline
post #3 of 4 Old 03-28-2002, 08:10 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
No batteries, it's wired in. I had the same problem, bought the Jeep and no clock. After getting out the magnifying glass and tracing the wiring diagrams in both the Haynes and Chiltons repair books I finally figured out the wiring and got it working. It's a real pain to follow the diagrams, but with a little patience and time you can trace the problem to it's source. What really made it hard was the a**h*le who owned it before me owned a pair or wire cutters and didn't know how to install a stereo.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #4 of 4 Old 03-28-2002, 09:43 PM
jfarrell
Just my $.02. You can double check the fuses. In my '90 YJ I found the fuse that is labeled "clock" and it was blown in an inconspicuous way. I really had to look but less than a buck later and I'm not late as much as I was before! I do have a 4 cylinder though, so you can figure that I'm still never on time.
jfarrell is offline
A/C Heater Dial Issues BlueTeeJay TJ Wrangler Technical Forum 8 03-25-2012 10:49 PM
AC blowing hot--temp dial in cold, but temp dial was previously in hot greendot200200 TJ Wrangler Technical Forum 6 11-14-2008 06:26 AM
A/C Fan Dial eastshores TJ Wrangler Technical Forum 3 08-30-2007 04:59 PM
Climate Control Dial Flyusaf2002 TJ Wrangler Technical Forum 3 12-13-2005 02:49 PM
New Bumper (Dial-up warning) GoGo TJ Wrangler Technical Forum 31 06-24-2005 11:18 AM
