diagnosis help. - JeepForum.com
post #1 of 8 Old 10-15-2011, 03:48 PM Thread Starter
willyb8
willyb8's Avatar
diagnosis help.
ok it all started couple wks ago when i dropped tank and installed new skid. pumped out as much gas as i could. now when i start it up for first time of day it runs fine. then when i shut it off and restart it it runs crappy, hesitates when i give it gas, kinda like trying to drive 10mph in 4th gear. i installed new fuel filter and that helped for couple days. think i pinched a fuel line when installed new skid? cleaned throttle body and tps. any ideas?
91 YJ 4.0 HO,
3.5" BDS, 5/8 MORE Booms, 1" BL, MML
AA SYE & CV,
35" Maxxis Bighorn
Smittybilt XRC8 Winch,
8.8 W/Elocker, D30 W/Aussie
Genright tube fenders
willyb8 is offline
post #2 of 8 Old 10-15-2011, 06:52 PM
timatoe
timatoe's Avatar
Assuming it is a vacuum line, maybe it's pinched enough that it's sorta "fluttering" inside the line.
timatoe is offline
post #3 of 8 Old 10-15-2011, 09:55 PM
moonshinefuel
I'd pressure test the fuel line. It should be a consistant 30 pounds of pressure, or maybe a bit more.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #4 of 8 Old 10-16-2011, 09:32 AM Thread Starter
willyb8
willyb8's Avatar
thanks, hope i dont have to drop tank again to check lines.
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
willyb8 is offline
post #5 of 8 Old 10-21-2011, 07:11 PM Thread Starter
willyb8
willyb8's Avatar
ok i went through vac lines. replaced 3 cracked ones. still runs great when first driven from cold start, when shut down for hour or so then restarted its sputtering. try to do fuel pres test tom. should i check plugs?
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
willyb8 is offline
post #6 of 8 Old 10-24-2011, 12:26 PM Thread Starter
willyb8
willyb8's Avatar
what about the 02 sensor, think it could be that?
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
willyb8 is offline
post #7 of 8 Old 10-24-2011, 12:42 PM
Que89YJ
Got an idea for you. Do like you've said previously. When you restart it if it is running bad shut it off and do a battery reset. See how it runs. You are forcing it into open loop again instead of the closed loop warm start. Check your fault codes:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is online now
post #8 of 8 Old 10-24-2011, 01:49 PM Thread Starter
willyb8
willyb8's Avatar
sweet thanks, i'll try that.
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
willyb8 is offline
diagnosis help please EDvorak YJ Wrangler Technical Forum 13 05-10-2009 04:46 AM
Help - Sputtering Diagnosis machinehead131 YJ Wrangler Technical Forum 2 04-09-2009 11:39 AM
diagnosis? jbeebe YJ Wrangler Technical Forum 14 02-04-2009 03:36 PM
In Need of a Diagnosis Jon2109 TJ Wrangler Technical Forum 10 07-01-2007 05:47 PM
Problem Diagnosis Help(Please!) 0blcktj6 TJ Wrangler Technical Forum 21 12-13-2006 06:33 AM
