Detroit EZ Lockers - JeepForum.com
post #1 of 9 Old 07-19-2001, 12:17 PM Thread Starter
Pantera
Detroit EZ Lockers
Dontcha just love people like me who spam the message boards looking for all sorts of ideas???
Anyway, my question... Anyone using Detroit EZ lockers??? Do ya like em??? I was thinking about getting some for me stock D30 & D35c axles... I guess I would consider them a temporary (few years) fix till I can afford to upgrade the entire drivetrain to a V8, T18 or NV4??, Atlas, D44 or D60... Are there any better alternatives??? The Jeep® is my daily driver, so I don't want to just get a spool... I also don't want to spent a lot of money... Ideas???
Eddie H.
91 YJ 4-Banger
Omaha, NE
Pantera is offline
post #2 of 9 Old 07-19-2001, 12:46 PM
rayray
rayray's Avatar
I run an EZ in my D30. Works fine and it's easy to fix if a problem occurs. I would recomend keeping your spider and side gears with you when you go wheeling. That way if the locker does fail, you can always swap out and still be mobile.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #3 of 9 Old 07-19-2001, 01:58 PM
Nightclaw
I have an EZ Locker in my D35, and have been generally OK with it. It's a touch squirrely on-road, but absolutely perfect off-road. As long as you recognize that it will add a certain element of, umm... excitement to on-road driving, you should be happy. This isn't specific to the EZ, but rather to locking diffs in general. Simply due to their nature, they will change the driving characteristics of the vehicle.
Oh, and if you do put a locker in your rear D35, watch out for ice patches in winter!
Nightclaw is offline
post #4 of 9 Old 07-19-2001, 03:00 PM
93YJ
I run an E-Z locker in my front D30. I have been pushing it with a V-8 and 37" tires with no troubles at all. It's been in there for about 2 years, and I'm pretty suprised at how well it has held up. I've even stripped all the teeth off of the front ring and pinion with no damage to the locker at all! I would definately recommend it. Chances are it's stronger then most of the rest of the axle.
Jay
www.txtrailriders.com
93YJ is offline
post #5 of 9 Old 07-19-2001, 03:43 PM
rayray
rayray's Avatar
ya know, I totally forgot about that. I blew my pinion to bits and the ez held up. Thanks for the memory jolt Jay
rayray
rayray is offline
post #6 of 9 Old 07-19-2001, 03:51 PM Thread Starter
Pantera
Ok then, from the sounds of things, get the EZ Lockers and I'll be sitting pretty ... Sweet guys... Thanks for the tips...
Eddie H.
91 YJ 4-Banger
Omaha, NE
Pantera is offline
post #7 of 9 Old 07-19-2001, 10:22 PM
osburn
osburn's Avatar
Just as a warning, they don't hold up forever in the rear. Since you've said this is temporary, this is exactly what I'd do too. Like RayRay says, carry your spider gears as spares in case it goes on ya. But keep in mind to change them, you need fluid and some RTV to seal it back up. Carry those too. Hell, everyone should be carrying some gear oil and RTV with them though. Right?
Matt Osburn
Score 1032
osburn is offline
post #8 of 9 Old 07-20-2001, 10:38 AM
rayray
rayray's Avatar
Yeppers, it goes between the duck tape and the mustard
rayray
rayray is offline
post #9 of 9 Old 07-22-2001, 04:48 PM
YJMCB
1987 YJ Wrangler
I will say that the ez-locker has more handling issues than the full detroit that I replaced it with after only 2 years.If you are installing it yourself it may be worth it ,but if you are paying to have it installed don't waste your time or money.YJMCB
87 YJ,SOA,35-12.50 Mickey Thompson Claws 92 XJ,8.8 detroit rear,35's & other stuff.
YJMCB is offline
Detroit Lockers Brads_nky_yj YJ Wrangler Technical Forum 24 03-24-2009 05:36 PM
Just to make sure – These are Detroit EZ Lockers, right? slush TJ Wrangler Technical Forum 7 01-19-2009 04:44 PM
Why are Detroit lockers bad in snow? nsmerilli TJ Wrangler Technical Forum 65 11-26-2008 12:30 AM
detroit lockers nyjeeperman TJ Wrangler Technical Forum 3 01-30-2006 01:30 PM
Detroit Lockers bulldozer TJ Wrangler Technical Forum 1 02-28-2002 11:46 AM
