desperately need help - JeepForum.com
post #1 of 8 Old 06-22-2013, 01:02 PM Thread Starter
benkashold
so iv had my jeep for a couple of years its a 89 yj im struggling to keep running its my daily driver right now. a couple weeks ago i was coming back home from a long drive and the gear at the end of the distributor that sits on the cam busted off my grandfather who pretty much built the jeep put a knew distributor on seemed to be running as good as ever lately its been running really rough back firing alot and a couple days it just wouldnt idle at all so i messed with the two screws on the carb a little seemed to be running fine yesterday i replaced all the spark plugs and two belts drove it around for 20 minutes was good i got home and noticed that a small hole in the back of the intake was hissing really bad i put my finger over the hole and it died i plugged a small hos coming from the fire wall into the hole they seemed to fit now it wont start or anything even whaen i unplug the hose. when i try to start it i get loud puffing sounds from the carb.
benkashold is offline
post #2 of 8 Old 06-22-2013, 01:46 PM
greyarea
I would check and adjust your timing. It also helps if you fi in al the details about your jeep in the profile.
90 YJ Magnum 5.2 v8 , 1'' BL, 1'' booms, 4" Procomp, 35/12.50-15 MTR/kevlar Ford 8.8 4.10 lsd Aussie and TJ shafts up front.
KI4UTU
greyarea is offline
post #3 of 8 Old 06-22-2013, 03:56 PM
Noltz
YJ Wrangler
Wow, ok that was very difficult to understand. You need to sort your information better so we can help you.
  • Your distributor gear drive sheered off, and you guys installed a new distributor. Everything ran fine.
  • Lately it's running rough, backfiring, poor or no idle. Tried adjusting the mixture screws on the carb and got it running fine.
  • Replaced plugs and belts (no change)
  • Found vacuum leak (hissing). Found loose hose, installed but now will not start at all.
First, I don't think your distributor is the problem at all. Sounds like it failed (fatigue), got replaced and is now good.
You probably developed a vacuum leak, causing your poor idle and backfiring. Vacuum leaks lean out the mixture.
You compensated for the vacuum leak by turning out the idle and main jet screws.
Leak got worse (hose fell off completely?), you found it. Put the hose back on, and now you're running super rich. Flooded engine, now won't start.
THIS IS ALL JUST THEORY.
My suggestion is to cap off the vacuum leak at the back of the intake. Do not put the random hose on it... you don't know for sure that's what it's there for. If you post a picture, we can try to help you on that later, but for right now use a rubber plug or duct tape over that nipple for now.
Put your mixture screws back where they were. If you don't know how many turns you moved them, the very rough setting for most carbs is 2 turns out from bottom. This means gently screw both mixture screws all the way down until the bottom. I cannot stress gently enough. That is now your Zero point. Turn each screws out 2 full turns.
You've monkied with this one pretty good. Hopefully you can get it close on your own or you may need to pay a mechanic. Talk to your grandfather about where to set the mixture screws if he's available.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #4 of 8 Old 06-22-2013, 04:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Noltz,
I always enjoy reading your well written posts.
Anticanman is offline
post #5 of 8 Old 06-22-2013, 11:32 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
@Noltz: I think you're close, but if you read closely, "gear at the end of the distributor that sits on the cam busted off my grandfather". Shouldn't he take his grandfather to the ER or Napa first?
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #6 of 8 Old 06-22-2013, 11:42 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Look out!! Grammar Gestapo is out looking for misplaced modifiers.
post #7 of 8 Old 06-27-2013, 05:54 PM
Luuca
Luuca's Avatar
YJOTM Sept. 2017
Luuca is offline
post #8 of 8 Old 06-27-2013, 07:13 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Oh the irony!!! Hahaha
OP did you listen to Noltz?
