#1 | |
Desert Rat Build
So I'm fairly new to the forum. Done a lot of lurking and info gathering for ideas on my Jeep build. I've decided to put up a build thread of my own since I have enjoyed reading other threads and know that everyone else seems to feel the same.
In July 2007 I was in an accident in which I lost my first vehicle. Which as you might guess was a YJ. It was a completely stock 1995 YJ 2.5L and my father bought it brand new. Might seem a pit sad, but you could say it was the love of my life.... Well I moved on to bigger and better things, there's always that silver lining. In October of 2007 I found a replacement in AZ. A green 1994 YJ, with a 4" lift, 33" BFG MT's, TJ seats, SYE, and 4:10 gears. Couldn't have been happier. I then flew out to pick it up and drive it home. Only to find out that it sounded like a ticking time bomb. I wasn't worried though, threw in some fuel system cleaner a few time's on my ride home and it was pretty much gone. I get home and start to do the little things. I did a Fire Power ignition upgrade, and then went on to change the oil. Here comes the sheer stupidity. I saw some engine cleaner and thought "What a GREAT idea!". Cycled it through the oil just like the bottle said and voila, it ran great. That lasted a week..... I go to drive home from some shopping and as soon as I turn the engine over, I though i mistaken climbed into a paint shaker. So after months of trying different things, I find out it's the valves. Apparently engine cleaner cleaned out the crap that held the motor together. The Jeep had been sitting under a cover since the end of Oct 2007 and just a few months ago I came into a position to fix it. But fix it I did not. I ripped the whole thing apart down to the last nut and bolt. So here I am with the with a thread to tell you what I have done and will keep updating as I continue. I will start as if from the beginning so I don't leave anything out. I will be reviewing all the products that I have used to hopefully help you guys out and vice verse. Seems everyone posts a list of planned mods, so here's mine: Axles: Rear Corporate 14 Bolt - Planning Stages Front Dana 60 - Planning Stages ARB Lockers 16" Rims - Not sure what kind 42" Tires Minimum - Planning Stages Suspension: M.O.R.E. 5-1/4" Boomerang Shackles - Done M.O.R.E. Shackle Reversal (It's my DD and offroader) - Done M.O.R.E. "Long Travel" Front Shock Hoops - On but need a weld M.O.R.E. "Long Travel" Rear Shock Mounts - Done M.O.R.E. SlickRock Spring Shackle Hangers (needed for the rear needed to level with the SRS) Bilstein 5150 long travel shocks - Have to figure droop and compression Chassis: Machine made Body Sleeves - Done Daystar Body Lift 1" - Done POR-15 and Chassis Saver everywhere, and I mean everywhere - Done R.E. Bumpstops Polyurethane bushings - Done Stainless Brake Lines - Partially done Stainless Gas Lines - They already are... Totally Stainless bolt kit - Getting done Body: Gen-Right Hood Louvers - Ready for install Chassis Saver on the whole tub - Done 3M undercoating - Done Raptor Liner in Spice - Done Xenon Tube Flares - Purchased, but will be up for sale due to a change in course Gen-Right Hi-Fenders - Fronts purchased Swag Offroad Tailgate Kit Drive Train: Running Junkyard motor (Temporary) - Done 186k though Rebuilt Engine to 4.6L Stroker - Camshaft, Crankshaft, Lifters Purchased AIRAID Cold Air Intake - Purchased 2005 I6 Intake Manifold - Done 2005 I6 Power Steering Pump - Done Hesco Throttle Body Spacer - Done Throttle Body Bored to 60mm - Done Fire Power Ignition - Done Borla Header (Jet Hot Coated) - Done Borla Cat-Back - Purchased High Flow Cat - Purchased Uni-Chip (Dyno Programed) - Purchased Coolant System: Ford Taurus Elec Fan - Purchased Hesco High Flow Water Pump - Done Stylin' Motors 4ply Rad Hoses - Purchased 5ply Heater Hoses - Purchased Electrical: Painless fuse block HID head lights Rear 3"x5" LED tail Lights Reverse Lights (thinking Gen-Rights) Interior: Lecarra steering wheel in Spice Tuffy 8" Stereo Console in Spice - Purchased Fat 50. Cal cans for wheel well Deuce and half Stowage boxes for rear Warrior Transmission Cover - Purchased
1995 YJ - Stock 2.5L, Taken out by a blind old driver. R.I.P. 1993 YJ - Stock 2.5L, Scrapped. R.I.P. [URL="http://www.jeepforum.com/forum/f12/desert-rat-build-830626/"]1994 YJ - Stock 4.0L, Currently getting the frame off treatment and being built up.[/URL] Last edited by gunnorthered; 08-27-2010 at 10:47 AM.. |
#2 |
wow jeeps just dont like you man lol but looking forward to this....
1991 yj 4.0 5-speed SOA 5.5 pro comp 35's SYE & CV DS// check it out!! http://www.jeepforum.com/forum/showthread.php?t=821885 |
#3 |
Let's see if I can get the images to work....
1995 YJ - Stock 2.5L, Taken out by a blind old driver. R.I.P. 1993 YJ - Stock 2.5L, Scrapped. R.I.P. [URL="http://www.jeepforum.com/forum/f12/desert-rat-build-830626/"]1994 YJ - Stock 4.0L, Currently getting the frame off treatment and being built up.[/URL] |
#4 |
All right I guess so, here are the others at the start. I took these right before I tore it down. I liked the green and all, but I'll be painting it Lackluster Sand Dust when it's done. I'm building the Jeep for the desert, hence the name, since I will be moving back out to AZ in the next two years.
#5 |
Here's a quick progression down to the frame.
#6 |
should be a good thread....
good luck
Started with some rust repairs ended in a SOA... http://www.jeepforum.com/forum/f12/how-make-big-hole-your-jeep-1050879/ family roll bar swap/upgrade.. http://www.jeepforum.com/forum/f12/family-bar-swap-upgrade-1054753/ 1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers |
#7 |
Suscribed...
JeepDVL45 "Real men hide their feelings, WHY?! BECAUSE IT’S NONE OF YOUR ****** BUSINESS!!!! Men do not cry. Men do not pout. Men jack you in the ******* jaw and say…thanks for comin’ out." - Boondock Saints II |
#8 |
The local sand blasting place wanted $250 to blast the frame and $500 to blast the tub. So I bought a sand blaster from Eastwood for $430. I have used it on the frame so far and it works great for the price. I have to say it can be quite time consuming, as well as dirty. I would how ever still have bought it knowing that now. You definitely need a good compressor that can keep up though. I had to run a two stage 5hp and a single stage 6hp with a combined capacity of 80 gallons just to keep it around 70psi. I spent two weekends with the single stage 6hpand had to break every 7 minutes for 10 minutes so it could recover. After they were setup in tandem it went great. I did learn that spraying everything down with a paint stripper the day before made life vastly easier. The reason I waited a day after applying the stripper was so the it could dry out and I could sift and reuse the sand.
Before and after of the grille mount: ![]() Here's the frame after I finished blasting: ![]() A leaf pack before and after: ![]() Last one, the skid plate: ![]()
#9 |
Ahhh! Take off, you hoser
Looks like your going to need a big broom and a big dust pan LMAO. My dad has a small snap-on sand blaster and it works wonders getting down to bare metal. Good job and keep the pics coming.
- 2000 F150 5.4L Lariat 4X4 Last edited by Hurley91; 10-06-2009 at 01:30 PM.. |
#10 |
I figure at the worst I'll just have a little beach next to the drive way. A chair, some beer, and my personal beach. Though my father wasn't so keen on the idea.
1995 YJ - Stock 2.5L, Taken out by a blind old driver. R.I.P. 1993 YJ - Stock 2.5L, Scrapped. R.I.P. [URL="http://www.jeepforum.com/forum/f12/desert-rat-build-830626/"]1994 YJ - Stock 4.0L, Currently getting the frame off treatment and being built up.[/URL] Last edited by gunnorthered; 08-04-2009 at 02:01 PM.. |
#11 |
So these are the shock hoops for the front. Just took a cutting wheel to the shock perch and cut off at the 4.5" line across the top. The only thing I need to do is have the hoop stitch welder on the sides. Unfortunately I don't have a welder, at least not yet.
After I cut the perch: ![]() With the shock hoop on: ![]()
#12 |
What both stock and the Hoop looks like:
#13 |
I ordered the bolt kit from Totally Stainless last night. I was pretty excited by the price considering buying some stainless steel bolts can cost a few dollars a piece. This Friday I'll be ordering my SS brake lines as well.
#14 |
Finished painting the frame. I used all POR-15 products. I wanted it to go without a hitch and hopefully never come off. You've probably heard this before, prep is key, and it's true. That's why I followed the instructions from the guys at Restomotive to the T. I have to say that anyone that wants to use POR-15 products needs to be patient.
Products used: 1 QT POR-15 Rust Preventative (black) 1 QT POR-15 Tie-Coat high build primer 1 QT POR-15 Flex-Cote top coat (Gray) 1 QT Metal Ready 1 PT Marine Cleaner 4 3/4" brushes 2 1-1/2" brushes 2 1" brushes 20 pairs of vinyl gloves Procedure: Step 1 - Sprayed rattle can paint stripper from Duplicolour all over the frame. Step 2 - Waited till it dried. (I only did it because of the sand blasting) Step 3 - Sand blasted the entire frame. This took about 2 days. Step 4 - Prepped the frame for the SRS and extended travel shock mounts. Step 5 - Sprayed Marine Cleaner (Parted 5:1) on the frame. Step 6 - Let sit for 5 minutes. Step 7 - Rinsed off Marine Cleaner. Step 8 - Sprayed Metal Ready on the frame and let sit for 20 minutes. Step 9 - Rinsed off Metal Ready. Step 10 - Let sit over night to completely dry. (I allowed it flash rust for better adhesion of POR-15) Step 11 - Applied base coat of POR-15 to the top of the frame. Step 12 - Waited 12 hours, flipped. Step 13 - Applied base coat of POR-15 to the bottom of the frame. Step 14 - Waited 12 hours, etched the surface with a Scotch-Brite pad, then wiped clean. Step 15 - Applied Tie-Coat to bottom of frame. Step 16 - Waited 12 hours, flipped. Step 17 - Etched the surface with a Scotch-Brite pad, then wiped clean. Step 18 - Applied Tie-Coat to top of frame. Step 19 - Waited 12 hours. Step 20 - Etched the surface with a Scotch-Brite pad, then wiped clean. Step 21 - Applied Flex-Cote to top of frame. Step 22 - Waited 12 hours, flipped. Step 23 - Etched the surface with a Scotch-Brite pad, then wiped clean. Step 24 - Applied Flex-Cote to bottom of frame. Done, finally Lessons learned: 1 - Try to suspend the frame in a fashion that will allow the whole thing to be coated in one application. 2 - Apply the top coat after the 2 hour mark or when still slightly tacky. This allows you to forgo the primer. 3 - If you have to use a primer the the Self Etching Primer for Restomotive is the best choice. It comes in a rattle can and you don't have to etch before or after application. 4 - Try and use the moisture cured paints on days that aren't 76% humidity. If anyone has any questions then let me know. Here's the shot of it primed, I'll get one of the finished work later. ![]()
#15 |
can't wait to see updates!
looks like it's gunna turn out great
89 yj 06 lj |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
